97 ex clutch upgrade
Old Feb 13, 2012 | 08:29 AM
svtford4x4's Avatar
Default 97 ex clutch upgrade
97 civic ex mostly stock for now, considering 8lbs, the clutch is showing some age and the isb is getting louder. probably changing the clutch and transmission for an ex trans soon and just putting together a parts list.
So looking into clutch's have read/heard good things about exedy clutches, also lightweight flywheels? my question is what is a good setup for d series?
Old Feb 13, 2012 | 08:34 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 97 ex clutch upgrade
What is "considering 8lbs"? If you're talking about boost then you don't know what you're talking about. If you're going boost then get a clutch rated to hold the amount of torque you'll be making. No real need for an aftermarket/lightened flywheel. If you're only thinking about going boost then get an Exedy OEM replacement clutch.
Old Feb 13, 2012 | 08:47 AM
NVturbo's Avatar
O.G. triple O.G.
For a D-series motor setup, Exedy or Competition Clutch would do fine.
Old Feb 13, 2012 | 02:39 PM
svtford4x4's Avatar
i've heard good things about the exedy, i'll stick with that.
rrdugas
Jan 22, 2014 02:44 PM
bigfinderman
Mar 15, 2012 03:53 AM
blackeg
May 17, 2008 07:32 AM
SOFLSOL
Oct 18, 2003 10:45 AM
