Suspension & Brakes Theory, alignment, spring rates....
ITR (5 lug) rear caliper question
Old Feb 12, 2012 | 10:19 PM
ej1bmx's Avatar
Default ITR (5 lug) rear caliper question
I searched around and had no luck of reverse searching the part numbers...
So I picked up a JDM CTR/USDM ITR 5 lug swap and one of the calipers were seized (left rear). Before I head down to pick up a re-manufactured one from the local auto store for $120+, I was wondering if anybody knew of any other OEM calipers that were interchangeable (same part number/size) that a local junk yard would likely have in stock (going rate of $14).
Any help would be greatly appreciated
Old Feb 13, 2012 | 10:03 AM
Ej8_KiD's Avatar
Default Re: ITR (5 lug) rear caliper question
RSX calipers fit but depends on what car you have you might have to invert them ( left caliper on right side and right caliper on the left side ) in order to have the bleeding screw on the angle
Old Feb 13, 2012 | 12:00 PM
phunhaus's Avatar
RSX are the same size but you probably don't want to mess with inverting and flipping to bleed. Stick with the ITR.
guru350
Apr 13, 2015 11:26 AM
guru350
Apr 6, 2015 09:45 AM
Teggy1999
Feb 6, 2014 07:38 PM
Lissav
29
Mar 17, 2006 11:07 AM
