99 Civic Si Muffler Replacement? Does OEM Type R fit?
Old Feb 12, 2012 | 01:28 PM
93grayeg's Avatar
Icon2 99 Civic Si Muffler Replacement? Does OEM Type R fit?
I wanna replace the muffler on my 99 Civic Si. The car is all stock and the muffler is in rough shape. Is the OEM Type R A direct bolt on? Thanks guys
Old Feb 12, 2012 | 08:36 PM
93grayeg's Avatar
Default Re: 99 Civic Si Muffler Replacement? Does OEM Type R fit?
wow, 214 veiws and no one know's?
Old Feb 13, 2012 | 03:39 AM
94EG8's Avatar
Seagull Management
It should work on a coupe/sedan. It wont fit properly on a hatch.
Old Feb 13, 2012 | 05:14 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Other way around. Works fine on a hatch. The coupe/sedan requires lenghtening of the pipe. The DB8 Itr Muffler will work if u can find one. The DC2 body is significantly shorter than the EM1.
Old Feb 13, 2012 | 05:21 AM
94EG8's Avatar
Seagull Management
No, not true at all. A friend of mine ran an ITR muffler on a hatch, we had to cut a good 6 - 8 inches off the tailpipe.
Old Feb 13, 2012 | 06:10 AM
kyden's Avatar
a 4 door integra muffler will fit perfectly. the 2 door is too short.
Old Feb 13, 2012 | 06:53 AM
B serious's Avatar
I guess u could be right. It's definitely too short for an EM1, though.
Old Feb 13, 2012 | 09:22 AM
93grayeg's Avatar
A lot of mixed opinions. Does anyone know for sure?
Old Mar 20, 2012 | 08:13 PM
93grayeg's Avatar
Still wondering about this before I throw 200 bucks down the drain
Old Mar 20, 2012 | 08:16 PM
Robin6's Avatar
it will bolt up but the fit will be incorrect. type r civic is a hatch which is shorter than the coupes at the rear. So the pipe will be further behind the rear bumper which will cause it to melt or catch fire. i see itr being mentioned above, same issue tho,
Old Mar 20, 2012 | 08:59 PM
zerovandez's Avatar
Regardless of what you do, be prepared to spend a little bit of money for a muffler shop to make it fit.
With the right amount of money, you can make almost anything work.
Old Mar 20, 2012 | 09:38 PM
crzycivic93's Avatar
bumpp
Old Mar 20, 2012 | 10:06 PM
jbpnoman's Avatar
Dude, stop going around bumping random posts.
Old Mar 20, 2012 | 10:08 PM
JDM_teh_WIN!!'s Avatar
It will bolt up fine but the tip will be shorter by like an inch or two. Not much difference between the two mufflers. Si muffler is $145
Old Mar 20, 2012 | 10:13 PM
PINEAPPLE's Avatar
Civic coupe, sedan, and integra sedan have the same length axleback.
To answer the OP's question, yes an ITR axleback will bolt up but come short of the bumper.
Old Mar 21, 2012 | 09:29 AM
93grayeg's Avatar
Thanks man, Does Honda still sell the Si muffler?
That's what I needed to know. Thank you.
1sic95accord
Sep 16, 2018 09:15 PM
retro23
Feb 19, 2009 07:12 PM
Joe Kickass
11
Aug 19, 2007 01:43 AM
spork sport
16
Feb 13, 2003 11:42 PM
Todd00
Aug 5, 2002 05:11 PM
