Re: help! car overheating & fan not turning on
Old Feb 12, 2012 | 09:44 AM
tlander's Avatar
Default Re: help! car overheating & fan not turning on
I have the opposite problem. I had the water pump, thermostat, all hoses radiator, radiator cap, thermostat sensor replaced. The car heats up but when i turn on the AC the Temp goes down. I replace it with all OEM parts.
1991 Honda Accord EX
Old Feb 12, 2012 | 10:07 AM
94EG8's Avatar
Seagull Management
Moved to Accord forum.
Old Feb 13, 2012 | 02:31 PM
Nonio's Avatar
Hi,
I had the same trouble when I first bought my 92 EX, second-handed.
The fan would only come on either when the a/c was on or when I pulled the key from the ignition.
Strange as this symptom sounds like, the whole thing was down to one small and inexpensive part.
If you pull the pannel underneath the steering wheel on the left and close to the bonnet opening lever, you'll find there's a small black box with a PBC inside. That unit's the controller for the car's cooling system. If it's not working properly it can easilly be the source of your problem.
Best of luck.
Old Feb 14, 2012 | 01:23 PM
Lost Again's Avatar
Jump the wires that go to thermo a (on the t-stat) with the key on....do the fans (both) come on?
Old Feb 17, 2012 | 12:50 PM
Nitemare's Avatar
Its your thermostat. I had the same exact problem onmy 94 Honda accord. The thermostat is under you hood. I used a big open end wrench. There's a wire with a plug going to it. Take off the plug, u will see to silver terminal. Bring you cat up to temperature when the needle starts to come up for the fan to come on. I used a metal paper clip and jumped it accorss the two terminals and the fan kicked on. I changed the thermostat, and problem solved
Jmullins665
Aug 27, 2017 09:40 AM
SaMally
Oct 9, 2016 06:00 PM
junior91hondaac
Oct 27, 2014 12:03 PM
PREACHERBREW
Aug 19, 2006 01:18 PM
B16Power
Mar 28, 2005 11:32 PM
