EG driverside door can only be opened and locked/unlocked from the outside
Hello HT, can you help me by identifying which part of the locking mechanism that always tends to break with most EG's so I hear. My driverside door can only be locked/unlocked from the outside but not inside. The little plastic lock on the inside is loose and just spins around. Does anyone know which part causes this to happen? I'm trying to find out what it is called and a replacement for it. Thanks!
Go to Majestic Honda and search the catalog. Your description doesn't really paint a clear picture of what you're talking about. As to what causes it? Jeez. These cars are pushing 20 years old. It's called wear and tear.
From: Pensacola, FL and every Court House in Louisiana
I had a plastic clip that holds the rod in place fall off and do the same thing. I went to oriellys to get the clip
Yeah I was told that it was because of some plastic clip, that I can get for cheap. I'm going to open my door panel and see for myself. Thanks again for the help
RALPHEEEEK
Jul 9, 2010 01:04 PM
FieldGenEJ
Jun 19, 2008 03:40 AM
Jonathan_ED3
37
Feb 27, 2003 10:00 AM
