attn: people with spoon cams. Valve lash ?
Old Oct 9, 2002 | 02:22 PM
pinota's Avatar
Default attn: people with spoon cams. Valve lash ?
Has the topic says. Someone knows the recomended valve lash for spoon cams ?
Does portflow inners and ti retainers will affect valve lash ?
Thanks,
P.S: My Spoon cams are on the way.
Old Oct 9, 2002 | 02:26 PM
sneakychaos's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (pinota)
Old Oct 9, 2002 | 02:33 PM
pinota's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (sneakychaos)
Need help on this, not
Need held from H-T, gurus.
Thanks,
Old Oct 9, 2002 | 02:35 PM
98itR484's Avatar
If you bought your spoon cams brand new * i think* they should come with a paper telling you what to gap it at. I know when you buy juns they come with a little manual type thing, and it says to gap at stock settings.
Old Oct 9, 2002 | 02:36 PM
spoon_ek9's Avatar
yea, wounder why u get a hummer. anyway, i dont know the exact lash for it, but since it got the same valve lift as stock itr cam, i think it should be same as stock lash.
Old Oct 9, 2002 | 02:38 PM
sackdz's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (spoon_ek9)
Hummer? lol
Reid's Avatar
Global Moderator
What is this for? Keep comments constructive.
Pinota,
Since the Spoon cams are fairly mild cams, I'd use stock valve lash on them unless they came with valve lash specs recommended by Spoon.
Old Oct 9, 2002 | 02:39 PM
spoon_ek9's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (sackdz)
Hummer? lol
yea, i think about that car too much
fyi, thats my drean tow truck.
[Modified by spoon_ek9, 11:40 PM 10/9/2002]
Old Oct 9, 2002 | 02:40 PM
pinota's Avatar
The cams have 600 miles on it. They´ll come in the box. I´m afraid cause i can´t read or translate japanese.
Why do you think i deserve , be paciente with your portuguese friend.
Nobody born with a B18C6 under his but.
Old Oct 9, 2002 | 02:56 PM
rainmanEK's Avatar
big strong guy
I would assume that factory R settings would work fine being the cams are very similiar! And the springs should not effect it! eric
Old Oct 9, 2002 | 03:03 PM
pinota's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (rainmanEK)
Many thanks, sweet.
Old Oct 9, 2002 | 04:24 PM
B2FiNiTY's Avatar
Stock valve lash
Old Oct 9, 2002 | 04:33 PM
TypeR 599's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (ExOdy)
stock should be right, JUN 3's are suppose to be stock valve lash.
Old Oct 9, 2002 | 04:55 PM
4-1-1's Avatar
I think there is a forum for you to post ***** in buddy.......
Old Oct 9, 2002 | 06:49 PM
AJ PwR's Avatar
Best results :
Intake 0.18mm
Exhaust 0.20mm
Old Oct 10, 2002 | 09:22 PM
B2FiNiTY's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (AJ PwR)
What are stock valve specs?
Old Oct 10, 2002 | 11:15 PM
AJ PwR's Avatar
A bit less.
Old Oct 11, 2002 | 05:50 AM
GM2000ITR's Avatar
New User
Stock recommended settings are: 0.06-0.07 intake & 0.07-0.08 exhaust.
Old Oct 11, 2002 | 06:52 AM
CHEETAH's Avatar
Best results :
Intake 0.18mm
Exhaust 0.20mm
actually int =0.17mm; exh = 0.19 works best on some of the cars I've done but I guess each motor is different or that canadian air is denser thant he US air LOL
greg
Old Oct 11, 2002 | 07:46 AM
pinota's Avatar
Default Re: attn: people with spoon cams. Valve lash ? (CHEETAH)
I´ll install them with stock cam gears. Can´t get aftermarket ones right now. no $$$.
Will i have any problems of running the Spoon cams with stock cam gears and head milled ?
I´ll be running both spoon cams retarded 2 degrees. ( 0.023 inches milled head )
Will the exaust cam too retarded and will have problems with bent exaust valves ?
By the way, already got the 97+ lude injectors for my setup.
Thanks,
Pinota
[Modified by pinota, 4:50 PM 10/11/2002]
Old Oct 11, 2002 | 10:01 AM
CHEETAH's Avatar
4 degrees at crank is not too bad unless you have really oversized valves with crappy valve reliefs, I noticed you list endy 82mm pistons , if so then you'll be fine.
try to at least put an adjustable intake cam gear to advance the intake gear a good 4 or 5 degrees.
Greg
Old Oct 11, 2002 | 10:10 AM
pinota's Avatar
Thanks for the info, CHEETAH.
I´m running stock valves.
I´ll get the cam gears has soon has possible, i wanna get the max output on the cams.
Thanks again.
DefiantGSR
10
Feb 7, 2004 05:58 PM
capcon83
Nov 5, 2002 09:16 AM
B2FiNiTY
Apr 23, 2002 06:08 PM
VtecNit01
Jan 21, 2002 10:20 AM
JDM R98
Aug 2, 2001 12:26 AM
