ECU HARNESS CONVERSION????
Old Feb 9, 2012 | 11:10 PM
HondaScene's Avatar
Default ECU HARNESS CONVERSION????
Would I need an ECU harness conversion if i get my ecu basemap changed to a p30? I'm currently running a p28 and its ****. since my car is an obd2 (99ekcoupe)
Old Feb 9, 2012 | 11:14 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: ECU HARNESS CONVERSION????
no you wont. you have a OBD2 to OBD1 jumper that should cover you with anything on the bay as well.all that would change is the fuel mapping... so you have DOHC running with a p28?
Old Feb 9, 2012 | 11:18 PM
HondaScene's Avatar
Yes sir, it runs like **** though, At lights i would idle at like .5 rpm. I killll a full tank of gas in 4 days nasty or what? Trying to get my p30 asap!
Old Feb 9, 2012 | 11:22 PM
Dead CIVIC's Avatar
Veteran: Army
yeah a good MAp will do the trick. if everything works fine now. It should be just fine with that chip.
Old Feb 9, 2012 | 11:42 PM
HondaScene's Avatar
Sounds good. ty
isayuhhhh
Northwest (Sales)
Jun 18, 2010 02:20 PM
Wonk Unit
Feb 11, 2007 10:26 AM
ElectronMan
Jun 14, 2002 06:49 PM
