Brake problems. Help before something happens..
Old Feb 9, 2012 | 09:56 PM
Freckles's Avatar
Default Brake problems. Help before something happens..
Civic hatch si '92. Bone stock.
Pretty much it has been swallowing brake fluid... Every week or so I have to fill up the brake fluid cause it goes to empty. If I press the brakes slow, no pressure and it goes all the way to the floor and only brakes a little bit. if I push it fast, it brakes like normal, but it feels like it has TOO much pressure.
Any ideas??
I do have rear disc brakes.
Old Feb 9, 2012 | 10:12 PM
91crx-jace's Avatar
Default Re: Brake problems. Help before something happens..
Check for something leaking like your brake lines or master cylinder.
Old Feb 9, 2012 | 10:41 PM
mmcd's Avatar
I would say there is a leak in the brake lines under the car somewhere
Old Feb 9, 2012 | 11:01 PM
Dead CIVIC's Avatar
Veteran: Army
park it. and hit the breaks hard and for a long time over and over. and you shall find where it's leaking when you take a look.
Old Feb 9, 2012 | 11:44 PM
mmcd's Avatar
This will be the easiest way
Old Feb 10, 2012 | 08:51 AM
Freckles's Avatar
While the cars on? Or off? Cause I heard that if you pump the brakes while the car is off you can pop brake lines?
Bird333
Oct 19, 2020 04:40 PM
civic1234
Feb 24, 2007 07:58 AM
CivicHP
Sep 30, 2005 01:32 PM
H.crx-si
Jul 6, 2003 10:05 AM
dnt94civic
Jun 7, 2002 05:04 AM
