what else do i need for my ls vtec build
Old Feb 9, 2012 | 07:49 PM
elton_23's Avatar
Default what else do i need for my ls vtec build
i bought a b18b1 block with je 11.5 pistons eagle h beam rods has 8k on it bored to 81.5mm ... ive got a b16a swap in the car now with a 99 si head unkown miles ... thinking supertech springs and retainers and valve seals and arp studs for a b18c ... i bought edelbrock street strip cams they where $175 brand new from the factory
Old Feb 9, 2012 | 08:42 PM
elton_23's Avatar
Default Re: what else do i need for my ls vtec build
also ive got a hytech tri y big tube header going on and its already got a 2.5'' exhaust
Old Feb 10, 2012 | 05:39 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
So what exactly is your question?
Old Feb 10, 2012 | 05:46 AM
eg6 type-R's Avatar
performer x manifold, injectors, and a good dyno tune
Old Feb 10, 2012 | 09:35 AM
DirtyDA9's Avatar
Don't use GSR head studs with a B16 head.
What is your question?
Old Feb 10, 2012 | 10:52 AM
elton_23's Avatar
my question is what parts do i need to finish the build... im not gonna finish the motor though ive got someone that knows what there doing just gonna bring them the parts and stuff
Old Feb 10, 2012 | 11:06 AM
TealCivic115's Avatar
plain and simple, you need a vtec conversion kit (golden eagle)
any other parts are at the buyers luxury for performance
Old Feb 10, 2012 | 11:17 AM
elton_23's Avatar
the block was set up for a ls vtec has t fitting off the oil pressure sender and a stainless line
Old Feb 10, 2012 | 11:25 AM
well then your set. get that head to a shop and have them inspect it for warpage and such. get it pressure tested and hot tanked for piece of mind. obviously a new head gasket is recommended and head studs. and your engine is now together.
what do the cylinder walls look like? upload pics if you can.
Old Feb 10, 2012 | 11:32 AM
elton_23's Avatar
walls look perfect too me glass smooth
Old Feb 10, 2012 | 11:44 AM
Then you are golden young man!! Any other questions?
Old Feb 10, 2012 | 11:46 AM
HellaFab's Avatar
glass smooth is bad.
Old Feb 10, 2012 | 11:48 AM
Pretty sure you are suppose to use B16 head studs from ARP.
Old Feb 10, 2012 | 11:52 AM
Then you may want to get your block checked out too. Since the previous owner most likely beat on it because it has forged internals, a rebuild might be the better decision in the long run. Let your machinist recommend what you should have them do.
Old Feb 10, 2012 | 12:32 PM
elton_23's Avatar
lame this build costing me money
Old Feb 10, 2012 | 12:36 PM
famous323's Avatar
^this, should have a nice cross hatch pattern.
Old Feb 10, 2012 | 12:41 PM
elton_23's Avatar
ill go take a pic
Old Feb 10, 2012 | 12:56 PM
elton_23's Avatar
it has that just saying when you feel it its nice and smooth
Old Feb 10, 2012 | 01:11 PM
DirtyDA9's Avatar
What did you expect? To not spend money on a build?
You will need new rod and main bearings, VTEC water/oil pumps and VTEC timing belt.
What are you going to be tuning with? And what about pump and injectors?
Old Feb 10, 2012 | 01:46 PM
m_shake's Avatar
when i built my gsr engine i was pissed that good parts and machine work cost so much money, i was told from mi boiz cus dat i could run 11's for like $250 doe...
Old Feb 10, 2012 | 01:57 PM
Str8EJ's Avatar
Where are you guys coming up with this?
Old Feb 10, 2012 | 05:09 PM
DirtyDA9's Avatar
^^ Uhh maybe the fact that b16 head studs are the shortest of any B-series?
Old Feb 10, 2012 | 05:11 PM
elton_23's Avatar
ok ill just bring it to the shop give them a blank check
Old Feb 10, 2012 | 07:10 PM
Str8EJ's Avatar
B16 studs are about 1/8" shorter than GSR. There's a reason why LSVs and GSRs share the same part number in the ARP catalog.
Curious, what's the rationale behind using a shorter stud? I've heard the cost argument before, but seriously...it's only 20 bux. And the OP's already planning to buy the right ones.
