help! car overheating & fan not turning on
Old Feb 9, 2012 | 05:01 PM
turbod16y8's Avatar
Default help! car overheating & fan not turning on
I've searched but found no answer.
1999 civic ex automatic
I have checked the fan fuse, relay and thermo switch.
It has a new thermostat.
When i jump the two wires on the thermo switch the fans would stay on.
Car is not smoking at all.
Wierd thing is, when i drive around for 20 mins the temp gauge stays above half way, fan not on, and when i open the radiator cap, there is no pressure. any input would help. thanks.
Old Feb 9, 2012 | 05:11 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: help! car overheating & fan not turning on
I had that issue before. What I did was unplug the 2-wire pin at the thermostat, and jumped the two wires so that the fan comes on whenever the engine was on. I know...it's a bandaid to an issue but I was never able to figure it out either. Perhaps, the thermo switch is staying in "open" position. Just like any sensor, it can go bad over time.
hannslebo's Avatar
Fan switch maybe...
Old Feb 9, 2012 | 05:15 PM
NVturbo's Avatar
O.G. triple O.G.
^^^ more than likely since jumping the wires do turn the fan on.
Old Feb 9, 2012 | 05:22 PM
hannslebo's Avatar
Yeah...Same problem with my old coupe...no fan...was able to jump it with a paper clip and finally ordered a fan switch off ebay and it fixed the problem.
Old Feb 9, 2012 | 05:35 PM
turbod16y8's Avatar
So i jumped the fan switch and drove around for about 30 mins and the temp gauge is still staying above halfway.
Old Feb 9, 2012 | 05:39 PM
NVturbo's Avatar
O.G. triple O.G.
The temp sensor is on the side of motor....single wire underneath the distributor. The one wire rubber "bullet" plug is what you are looking for.
Old Feb 9, 2012 | 07:24 PM
motegicivic's Avatar
Is this car turboed?
Wow so you jumped it and the fan still did not bring the temp down, so that means even if you do the fan switch it will not help.
A few things, make sure you are not low on coolant.
Have you bleed the cooling system, might be air.
Since it is constantly high, could be a bad water pump, maybe radiator.
I would pressure test it.
Last resort headgasket.
Old Feb 9, 2012 | 07:53 PM
turbod16y8's Avatar
car isnt turboed.
coolant is full
how can i tell if its a bad water pump? I notice when the car is up to temp and with the radiator cap off. i dont see the coolant flowing. Is it supposed to be bubbling?
I dont think its the headgasket because theres no smoke coming from the exhaust and im not losing coolant nor oil.
Old Feb 9, 2012 | 11:05 PM
Dead CIVIC's Avatar
Veteran: Army
i had the same issue. then i swapped out the motor and noticed it had the same issue...? well i learned that it was my radiator cap.
try replacing it. and it should work. cuz it seem that your fan is good, temp fan switch is good and thermostat is good.
it has to be the rad cap. it will give you those side effects when it goes bad.
please come back and post if it worked. good luck.
Old Feb 10, 2012 | 06:55 AM
If you do not see the coolant flowing could be a bad water pump.
Was the water pump ever done, or recently?
By the way do not drive it at 3/4 for too long, still way hotter than it should be.
Old Feb 10, 2012 | 06:58 AM
kyden's Avatar
does your lower radiator hose get hot?
Old Feb 10, 2012 | 01:16 PM
turbod16y8's Avatar
yes lower radiator hose gets hot. so i know the thermostat is working. im going to try a new radiator cap first. I dont think the water pump was ever changed.
Old Feb 10, 2012 | 03:09 PM
Dead CIVIC's Avatar
Veteran: Army
yeah replace the cap. i wanna know if that helped you out. I have two other friends that had the same issue and i told them the same thing and .... wallah
Old Feb 10, 2012 | 09:21 PM
If you run it without the cap and see no movement chances are it is more than just the cap.
Old Feb 11, 2012 | 05:11 AM
Former User's Avatar
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
Old Feb 14, 2012 | 12:26 PM
turbod16y8's Avatar
heres a video. i did what you said. cap loosen, front end higher than rear, heater on blast, this video is with the cap off and at operating temperature. fan never kicked on. temp started to rise above halfway.
http://youtu.be/xpm9icmDwYQ
Old Feb 14, 2012 | 03:44 PM
It doesn't seem like it flowing, like I said before might be water pump.
Old Feb 15, 2012 | 09:02 AM
turbod16y8's Avatar
Can the water pump be that bad to not circulate the coolant? I just bought a new radiator cap today so going to test it see how it goes.
Old Feb 15, 2012 | 10:04 AM
Yes, how long have you had the car? Any record of the timing belt done? As you know when you do the timing belt you do the water pump as well.
Old Feb 15, 2012 | 11:57 AM
turbod16y8's Avatar
i just bought the car. No record of timing belt change.
Old Feb 15, 2012 | 12:00 PM
Freckles's Avatar
Same thing happened to mine. Try connecting a ground from the fan's relay directly to the battery.
Old Feb 15, 2012 | 12:31 PM
turbod16y8's Avatar
new cap doesnt work. same problem. fan doesnt kick on and still overheats. Im starting to think it is the water pump.
Old Feb 15, 2012 | 12:32 PM
turbod16y8's Avatar
well the fan is running right now but its being jumped at the fan switch but it still overheats. needle Stays just above the normal operating temp.
Old Feb 15, 2012 | 12:36 PM
Danielson22's Avatar
If there is no flow, then it is most likely the water pump.
