Car won't crank
Old Feb 8, 2012 | 11:04 PM
playertwo's Avatar
Default Car won't crank
Battery is at 12.6 volts, positive terminal to starter is also same volts. Whenever I try to start it I hear some buzzing noise from the dashboard. could it be ignition switch?
Old Feb 8, 2012 | 11:25 PM
maddix's Avatar
Default Re: Car won't crank
maybe ground on the engine lost.. and else watch safety fuse
Old Feb 9, 2012 | 04:58 AM
90civic-ZC's Avatar
Sounds like your main relay.....I've heard they'll buzz if the ground doesnt have a good connection. It's the wire bolted to your thermostat housing...you cant miss it. Check to see if it's loose, broke, or if there's too much corosion around it. Hope that helps, get back to us if it doesnt work.
Old Feb 9, 2012 | 05:35 AM
crvtectim's Avatar
Make sure the 15A ecu fuse in the engine bay isn't blown.
Old Feb 9, 2012 | 10:10 AM
playertwo's Avatar
I checked the ground on the thermostat and it looks good no corrosion. and my fuses are all good. Any other ideas?
Old Feb 9, 2012 | 10:32 AM
4drEF's Avatar
Keyboard Humorist
Is your battery in good condition?
Is it 3 years or older?
Check battery ground, battery to chassis ground, chassis to tranny ground. and cylinder head to chassis ground.
Even if they look good, unbolt them all - including the thermostat ground - and clean them up for good measure.
Old Feb 9, 2012 | 11:44 AM
playertwo's Avatar
i unbolted and rebolted the grounds and i tried jump starting the battery and it still dont work, i just took it to autozone and they said it was good and recharged it
Old Feb 9, 2012 | 02:13 PM
playertwo's Avatar
battery-check
starter-check
ground-check
ignition switch-check
starter relay- check
main relay- check
so what am i missing?
Old Feb 9, 2012 | 02:41 PM
FSRslug's Avatar
Originally Posted by playertwo
battery-check
starter-check
ground-check
main relay- check
Do you have 12V at the starter solenoid connector when the key is turned to start? How do you know your starter is good?
Old Feb 9, 2012 | 02:51 PM
crvtectim's Avatar
Might be the clutch switch.
Old Feb 10, 2012 | 07:14 AM
playertwo's Avatar
ok i solved it. i just changed the ground location for the one that connects to the frame. thanks all
Mason Edmison
Oct 22, 2017 09:19 AM
prodjay10
Honda Civic (2001 - 2005)
Dec 14, 2016 12:12 PM
SMOOTHN
Jul 31, 2010 07:45 PM
oneprelude
Apr 26, 2009 08:49 AM
Colombiano127
Dec 13, 2007 07:17 PM
