1992 HONDA Accord broken balancer belt
Old Feb 8, 2012 | 09:18 PM
demondog77's Avatar
Default 1992 HONDA Accord broken balancer belt
The balancer belt broke and I replaced it and now I have a vibration at idle and low rpms. I also noticed a knocking noise in the valve cover since i replaced the belt. Can someone help me out. Is the a position fro the oil pump pulley to be aligned. and is it possible the balancer is out of alignment. what might be the noise?
Old Feb 8, 2012 | 09:47 PM
nus_dogg's Avatar
Default Re: 1992 HONDA Accord broken balancer belt
Yes, you'll need to get the front and rear balancer pulleys aligned when installing a new belt; otherwise, you'll experience some vibration. If you search, you'll find some pictures and how to go about timing the balancer pulleys.
Old Feb 9, 2012 | 07:39 AM
S.O.R.'s Avatar
Would also be a good time to replace your motor mounts if they are old, worn, and broken.
jsqu03
Jul 11, 2014 01:37 PM
strinm02
May 5, 2014 06:47 AM
BPA
May 6, 2013 11:32 AM
accordcle
Nov 24, 2012 10:56 AM
famfive
Jul 25, 2010 08:29 AM
