F.Y.I. 88-91 OEM CRX Labels part numbers
If you are looking to restore your CRX back to OEM, there is nothing nicer than having
the correct labels on your parts to give it that 100% OEM factory look.
Here's some info I dug up, that dont sometimes show on dealer parts lookups.
Spare Tire plate Caution:
Part Number: 42767-SA5-670
Underhood Information Service & Emissions Label
w / o Calif Injection System
DX Model
1988 17277-PM5-A01
1989-91 17277-PM5-A02
HF Model
1988 17277-PM8-A00
1989-91 17277-PM8-A01
Si Model
1988 17277-PM6-A00
1989-91 17277-PM6-A01
w / Calif Injection System
DX Model
1988 17277-PM5-L01
1989-91 17277-PM9-L11
HF Model
1988 17277-PM8-L00
1989-91 17277-PM8-L01
Si Model
1988 17277-PM6-L00
1989-91 17277-PM6-L01
Fan Caution Label (Located On radiator)
w / Toyo Radiator
1988 19018-657-000
1989-91 19018-P08-000
w / Denso Radiator
19018-PK1-003
Upper Timing Cover Label (Located ontop of upper timing cover)
31117-PM5-A00
Tire Pressure Label (Located on left side inside Glove box)
DX Model
1988-89 42760-SH3-T30
1990-91 42762-SH3-A50
HF Model
1988-89 42760-SH3-T10
1990-91 42762-SH3-A40
Si Model
1988-89 42760-SH3-T50
1990-91 42762-SH3-A61
Fuel Filler door label (Unleaded Fuel Only) (Located inside Fuel door)
17669-SA0-670
Intake Manifold decal (PGM-FI)
(MULTI PORT/PGM-FI) 17113-PG7-310
(DUAL POINT/PGM-FI) 16489-PM5-A00
Fuse Label under dash
77762-SD4-000
Ignition Switch "Push" Label (Located on steering column cover)
53231-SB2-000
Reserve coolant tank Label (Placed ontop of coolant tank cap)
19105-PM3-000
Airbox intake info Label (Located ontop of airbox)
1988-89 17273-PE7-661
1990-91 17273-PM5-A00
Fuse Box Label (Located ontop of engine bay fusebox - comes with fuse box lid only)
38250-SH3-961
Rear model decal
75723-SH2-A21ZB - Si (red)
75723-SH2-A00ZE - HF (light grey)
Rear Grey 'HONDA' decal
75712-SH2-000ZJ
Front Hood chrome 'H' Emblem
75700-SG0-000
1991 Special edition door decal
75772-SH2-C91ZA
'CRX' Rear Garnish Decal
08999-DEC-540
update: Clear round stickers where the black grommets contact the door/hood/hatch of the body
Part Number: 85268-SA0-000
Before:
After:
DX Model
1988 17277-PM5-A01
HF Model
1988 17277-PM8-A00
Si Model
1988 17277-PM6-A00
DX Model
1988 17277-PM5-L01
HF Model
1988 17277-PM8-L00
Si Model
1988 17277-PM6-L00
w / Toyo Radiator
1988 19018-657-000
w / Denso Radiator
19018-PK1-003
31117-PM5-A00
DX Model
HF Model
Si Model
17669-SA0-670
77762-SD4-000
53231-SB2-000
19105-PM3-000
38250-SH3-961
Rear model decal
75712-SH2-000ZJ
75700-SG0-000
75772-SH2-C91ZA
08999-DEC-540
Before:
After:
I odered four decals on 7/03 from Sons Honda (local so I can pick up). I'm waiting on refunds for the ones not available. I'll update this once I see which ones are not available.
1 EMBLEM, IN. MANIFOLD (PGM-FI) 17113-PG7-310 $9.90
1 LABEL, FAN CAUTION 19018-657-000 $2.77
1 PLATE, CAUTION 31117-PM5-A00 $4.02
1 EMBLEM, REAR (RED) (SI) 75723-SH2-A21ZB $8.03
I'm pretty sure the rear emblem is discontinued but I can get one off ebay.
I really like the Special Edition door decal but couldn't get it to pull up online. Anyone know how I can try and order one?
Thanks!
Thanks!
Look at 1991 CRX Si.
http://www.canadianhondaparts.com/Pa...per&illid=9532
Here: http://www.canadianhondaparts.com/OrderParts.aspx
Not sure I want to try and order them or not. Thanks for the link!!
Thanks!
Thanks!
I've seen the rear red Si emblem on ebay but none of the others.
Here is another one to add to the list for those of you with CRX's that were actually made in Japan. BTW: I didn't host this picture myself, so you may want to copy & re-host it so it doesn't disappear in a year or two.
Made in Japan = 87125-041-680
Still looking for the part number for this one found on the Candian Civics & CRXs. Anybody know?
Made in Canada = ??? (might be 87125-S10-A00)
***edit: HFC134a sticker is 80050-SP0-000
I "think" (not positive) these are the codes for the Del Sol VTEC emissions labels. Not sure which one is which year though, so you will need to contact your parts dealer to be certain. I would think 1994 would be A00 and go up from there. You will need at least a correct vin number to order the emissions label, so be aware.
17277-P30-A00
17277-P30-A01
17277-P30-A02
17277-P30-A03
17277-P30-A00
17277-P30-A01
17277-P30-A02
17277-P30-A03
