y7 block +z6 head + greddy turbo tdo4 HELP!
Old Feb 8, 2012 | 02:57 AM
ShoTymeFonz's Avatar
Default y7 block +z6 head + greddy turbo tdo4 HELP!
So just swapped a d16z6 head onto my d16y7 block with a greddy td04 kit. Only problem is I went to start the car and she cranks but won't fire. I'm getting fuel, I pulled the number one spark plug and got spark, and I know compression is good. I put my cam at 4 degrees retarded using an adjustable cam gear. Another thing I'm thinking is it could be the dizzy cuz its def not a z6 dizzy. Not really sure what model it is but its obd1. I'm even running the z6 harness, and p28 ecu. Im stumped. Either timing or dizzy is tweeked... Could it be that this dizzy could have different sparking contact points? Should I try settin cam gear to 4 degrees advanced? All insight would help thanx.
Old Feb 8, 2012 | 05:03 AM
tron_'s Avatar
10 Year Member
Default Re: y7 block +z6 head + greddy turbo tdo4 HELP!
Are the plugs from the distributer connected to the correct plug?
Old Feb 8, 2012 | 06:48 AM
wmac's Avatar
use a z6/z1 (td42u) distributor, and check firing order
Old Feb 13, 2012 | 02:10 AM
Well got her running. Surprisingly the plugs were in too tight lol. But got the 450cc injectors in and wired some resistors inline. Ecu its chipped on CP on a z6 turbo basemap. Heres my problem now.... She runs beautifully but one it comes too an idle it bounces between 0-1k it won't die but gets close too it... Any suggestions?
Old Feb 13, 2012 | 03:49 AM
tron_'s Avatar
10 Year Member
I would start by checking for vacuum leaks and cleaning out your IACV if it hasnt already been cleaned.
Old Feb 13, 2012 | 05:48 AM
grumblemarc's Avatar
The Grumpiest
If your CROME basemap wasn't done right it'll do that surging thing. I know this firsthand. Had a local guy make me a CROME basemap and it did that. Got a basemap from Phearable and no more surging right up until the tune.
Old Feb 15, 2012 | 03:30 AM
Well is it normal for only the idle to be off? Ima try to burp the engine for air in the coolant. It only happens when car is warm
DaCivicSWAP
Jun 14, 2012 12:56 PM
Civstang
17
Aug 22, 2011 05:08 PM
gsrcivic9
Dec 14, 2009 10:05 AM
kinkyintegra
Nov 8, 2008 12:03 PM
mike93eh
10
Aug 7, 2005 04:34 PM
