Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Rev Limit Change!!
Old Feb 7, 2012 | 07:11 AM
ruggierosi16's Avatar
Default Rev Limit Change!!
Is there a way to raise the Rev Limiter on my stock 08 Si? All I have is a Skunk2 2 1/2" exhaust and AEM short ram intake.
Old Feb 7, 2012 | 07:15 AM
flmzero13's Avatar
Default Re: Rev Limit Change!!
never have i owned any civic 2000 and up but i imagine the only way u can do that is by building the bottom end
Old Feb 7, 2012 | 07:57 AM
I ment where you idle and hit the gas and it wont let you go over a certain rpm until you let off the clutch
Old Feb 7, 2012 | 08:42 AM
420Coupe's Avatar
HONDATA flashpro and a tune will solve the Rev hang and greatly improve driving experience possibly even a few more hp to the wheel
Originally Posted by kb2wji
I've got an '11 FA5, bone stock. The cars pretty nice, but the rev hang was killing it for me, soooo I got FlashPro. I installed a base map, and it reduced the rev hang. Reduced to the point of not wanting to drive my SI of an overpass, but not gone. Basically pretty happy about the FP.
Enter VitViper. I figure hell, i've already spent a bunch of $$ on a FP, why not spend a little more and make it that much better. I bought a tune, and started datalogging. Vit helped me out every step of the way! I'm a tuning noob, a computer noob, and defenitely a FP noob. I was a little apprehensive about plugging something into my car that could essentially make it explode into little pieces of radioactive powder. He walked me through the datalogging process, and then the recalibrating process. After a few email exchanges of datalogs and new calibrations, my car is transformed. Mind you, my car is bone stock with the exception of a trailer hitch (+3whp) and tinted windows (+7whp). BIG DIFFERENCE!! My car runs as smooth as butter! Low rpm in-traffic driving is super slick, and the throttle response is very sharp. The VTEC transition hits nice at WOT, but super smooth at part throttle. It's what Honda should have done from the factory. Plus, knowing that my engine is running "safely" is itself worth the tune $$.
In closing, all SI's need a FP, and an E-tune. Yea, even if you're bone stock.
:cheerleader: Thanks Vit!! :cheerleader:
Old Feb 7, 2012 | 09:16 AM
Yea i knew a chip would do it but is there any way to raise it without. Chip?
Old Feb 7, 2012 | 11:12 AM
freakin_eLRoD's Avatar
no. unless you have flash pro, access port, or something to that nature. that neutral rev limit was set there by honda probably to prevent idiots from blowing their motors from pointless high revving while the engine is not under any kind of load.
Old Feb 7, 2012 | 06:42 PM
originalg00kster's Avatar
yeah i don't think you should be able to own flashpro...you'll probably save yourself a lot of money. I can see the kid now just revving the **** out of his motor and over revving....ka boom.
Old Feb 7, 2012 | 07:23 PM
tpatt's Avatar
I've always wondered why the engine seems like it's working so much harder while in P or N. You bring it to 2k and it sounds like a workhorse, but at 60mph, it sounds like it's barely above idle. Does a load significantly reduce stress, wear, and tear on the motor? It sure sounds like it.
Old Feb 7, 2012 | 10:22 PM
I want to be in your sig's Avatar
I'm going have to guess wind noise, the road noise created as the tires rolls across the pavement, other cars' noise, other outside noise, etc.
Old Feb 13, 2012 | 03:27 AM
Ohh i see. Well i talked to a few people and i figured out that I shouldn't need to change my rev limit. Its in the perfect spot now unless I beef up the engine alot more. Thanks guys
fandirabbani08
Feb 16, 2007 12:47 PM
04Sispeed
Apr 25, 2005 04:10 AM
93egSIboi
35
Dec 16, 2004 01:34 PM
WhatItDo
Oct 26, 2004 08:49 PM
PnX-R
Nov 12, 2002 10:51 AM
