FS: OBD1(eg) wiring harness WIRED for B-series
wired meaning vtec ready to pop. no check engine lights from a half *** harness.
This harness has been in a box for over 3 years i cant remember if it has the knock sensor added i have to check
Not so sure..i might be wrong but that harness looks to be obd2...from 96+ civics. Reason i say this is i see that the rubber boot in were the harness goes into the ecu through the firewall has the metal clip..only 96+ civics have that.Another reason why i think it might be an obd2 harness is that i see a blue connector which comes on obd2 harness.
The obd1 92-95 civics engine harness stops at the shock towers.
Maybe its just the picture that makes it look.
Not trying to be rude or anything, just want to help out.
Bump for you..
Bump for you..
