Clock light doesn't work
The clock no longer lights up at night. Simple fuse fix?
Most likely the bulb, see them all the time.
I was assuming he already checked the bulb. That would be the obvious first step
Low blow Nick.
I guess I'm notorious around here.
Well, it's my g/f's car and I didn't have time to check anything last weekend. Is the clock hard to take out? I'll just get a flathead and work on it.
I guess I'm notorious around here. Well, it's my g/f's car and I didn't have time to check anything last weekend. Is the clock hard to take out? I'll just get a flathead and work on it.
It's the light behind the clock. Very common. The whole dash bezel around the instrument cluster and clock comes out as one piece. The bulb is only a few bucks. Don't try to pry the clock out of the dash, it's bolted in from behind. Good luck.
Just curious about your 14,000 posts. Is that for real or did you just hack the code or something?
Oh, and you might want to put a thin piece of tape on the end of the skinniest flathead you can find. Keeps it from scratching anything.
GSlowR
12
Oct 5, 2002 07:14 PM
