Ex Knuckles
Old Feb 6, 2012 | 05:01 PM
Edwin909's Avatar
Default Ex Knuckles
How can I identify EX knuckles from other knuckles?..... And what tools and sockets would I need to take some off a vehicle
Old Feb 6, 2012 | 05:13 PM
crx_si-r's Avatar
Default Re: Ex Knuckles
easiest way to tell is that the calipers will have mounting brackets. as for actual stamping numbers here is what you look for:
Old Feb 6, 2012 | 05:16 PM
Edwin909's Avatar
Would you recommend getting the calipers aswell for a brake upgrade or just hold off and get itr brakes since that's what I'm planning to do, you know the size of the sockets I need to take the knuckles off
Old Feb 6, 2012 | 05:36 PM
crx_si-r's Avatar
i have ITR calipers if your interested with the mounting brackets.
you mainly need a 17mm, 10mm, 32mm (for axle) and a hammer and pickle fork
Old Feb 6, 2012 | 06:22 PM
KINGVEM^^ED6's Avatar
Plyrs too
Old Feb 6, 2012 | 07:00 PM
Edwin909's Avatar
Sounds good, let me get the Knuckles and maybe I'll hit you up
Old Feb 7, 2012 | 07:08 AM
Edwin909's Avatar
I have the calipers with brackets so now I know they are not stock but know I need to know if they ate either DA or SiR knuckles?.... The right knuckle is stamped 3EC
Old Feb 7, 2012 | 08:34 AM
4drEF's Avatar
Keyboard Humorist
This is about as detailed of a comparison as you can get.
http://www.angelfire.com/ca/DrOhm/SiRkuckles.html
Old Feb 7, 2012 | 04:39 PM
Edwin909's Avatar
So I think ive come to the conclusion that i have overseas ef knuckles, went to the junkyard and DA knuckles were stamped with a K, anybody know the part number for overseas ef calipers?... Would it be worth getting the EX knuckles instead for 70 bucks?...
Old Feb 7, 2012 | 04:56 PM
90_EX_Civic's Avatar
ex knuckles will have a better suspension geometry. da's will fit too, but it is said if you can get a hold of ex's, get them instead.
Old Feb 7, 2012 | 05:02 PM
Edwin909's Avatar
Yea but i think i have overseas ef knuckles so in other words ef9 knuckles, and im wondering how they compare to EX knuckles
Old Feb 7, 2012 | 05:13 PM
dh's Avatar
dh
Si-R knuckles are stamped RH3-N and LH3-N.
Old Feb 7, 2012 | 06:11 PM
Edwin909's Avatar
Then I have no idea What knuckles I have
Old Feb 7, 2012 | 06:20 PM
canadian?
Old Feb 8, 2012 | 12:08 PM
Edwin909's Avatar
What's the stamp on the Canadian ones and si
Old Mar 20, 2020 | 09:33 PM
Efmysedan's Avatar
what should the stamp be ???? On the knuckle
Old Mar 21, 2020 | 10:57 AM
Tyson's Avatar
The picture says LH3-A and RH3-A.
Old Mar 21, 2020 | 05:06 PM
Efmysedan's Avatar
The knuckles on my eg ex are stamped 5BL and 5C3. In case anyone ever comes across knuckles stamped the same. Don’t worry there the same as those in this thread. Today I found some 23T caliper brackets off a accord with a v6 2001 I think. I compared the brackets to those off 2001 and 2004 Acura TL’s they were the same but the rotors from Acura TL to v6 accord were bigger and thinker than the accords. So they were probably the 28T bracket versions.
Old Mar 21, 2020 | 05:08 PM
Efmysedan's Avatar
to answer this my eg’s vin starts with a 2 I think that’s Canadian so Canadian eg ex knuckles must have a 5BL and 5C3 stamp
Old Mar 21, 2020 | 09:27 PM
Tyson's Avatar
That's cute, wrong EX.
This is the EF forum, not Eg.
Thanks for replying ... It's really helped.
Old Mar 22, 2020 | 10:06 AM
Efmysedan's Avatar
dont ef owners go looking for eg knuckles????
jack***
Old Mar 22, 2020 | 10:19 AM
Tyson's Avatar
No, because they don't fit right in EF.
Lol
Look, perhaps you just don't know what this thread is about.
90-91 EX Sedans had larger brakes, same as DA front brakes. They fit perfectly on EF, because it is an EF. DA knuckles mostly fit, but there positive camber and sharp dynamic camber and toe change issues. Acceptable, but not ideal like EX knuckles. Unfortunately EX sedan knuckles are rare, because of lower sales and most have been junked.
EG and EK knuckles have never been recommended because they completely mess up suspension geometry. More than DA. Nothing positive, certainly not just for bigger brakes, there's other options for that.
So GTFO with your EG knuckles. Lol.
Old Mar 23, 2020 | 07:03 AM
shortA25's Avatar
Though it’s implied in the thread above and can be found easily via a quick search, just for clarification, 90-91 Civic EX knuckles are stamped LH3-A (driver left) and RH3-A (passenger right).
Old Mar 23, 2020 | 07:44 AM
Khcoyfyifyd's Avatar
Cool
Old Mar 25, 2020 | 02:39 PM
Efmysedan's Avatar
Y’all were right. I was supposed to look online to verify before I swapped it but I was too impatient haha
BombSquad91
Apr 18, 2014 11:46 AM
Turbo_Mike
Jun 22, 2008 05:53 AM
ludesrv
Feb 18, 2008 05:31 PM
steronz
Dec 19, 2006 04:54 PM
