help! burning oil bad?
Old Oct 9, 2002 | 11:53 AM
Skunk_it's Avatar
Default help! burning oil bad?
I have a 2001 GS-R and I recently switched my oil to mobil 1 synthetic 5W-30 I was running chevron 10W-30. I have i/h/e and I'm burning oil fast. I burnt about a quart in a three days. And when I get on it and it hits vtec it smokes quite a bit out the exhaust. Please help me. thanks
Old Oct 9, 2002 | 12:01 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: help! burning oil bad? (GS-Right)
Maybe you should try 10W30.
Old Oct 9, 2002 | 12:03 PM
asianautica's Avatar
I think the best way is to go what to what you had before. Unless you burn oil before too, then go get it check out.
Old Oct 9, 2002 | 12:58 PM
es four's Avatar
Default Re: help! burning oil bad? (asianautica)
Don't do that....once you go to a full synthetic, you are supposed to keep using a full synthetic, nothing else! Just try a different Viscosity Mobil1.
Old Oct 9, 2002 | 01:19 PM
Fuuma0083's Avatar
Default Re: help! burning oil bad? (integra707)
go get yourself 10W-30 syn. Mobil One. But if your burning alot... well datz another story.
Old Oct 9, 2002 | 01:31 PM
Tweakmeister's Avatar
Default Re: help! burning oil bad? (Fuuma0083)
that is the nature of Mobil 1. Try and get 5w40 and check your levels often.
or go with Redline 5w30 (much better oil) if you can.
or go back to something like Castrol GTX 5w30 dino.
or go another route
Old Oct 9, 2002 | 01:48 PM
3rdGteg's Avatar
Default Re: help! burning oil bad? (Tweakmeister)
If it's not the oil, then you better save some money for a valve seal job or piston rings.
Old Oct 9, 2002 | 02:14 PM
Regular Series's Avatar
First off, don't get on it anymore.
Secondly, I'd bet you have one or more bad valve stem seals. I think if you had bad rings you would get constant smoke from your exhaust (can anyone confirm this?). Do you get smoke on a cold start (sitting overnight)? That is another reliable indicator of bad valve stem seals.
Take it to Acura, you're probably still warrantied.
Old Oct 9, 2002 | 03:02 PM
It's Blue's Avatar
New User
Default Re: help! burning oil bad? (risingson77)
It more an likely is going to be your rings. My car is like that if I get on it and I have 2 piston rings that are gone. Do a compression check and a leak down check to be for certain. A quick way to figure it out if you don't have access to a compression tester is this. When does the car smoke, 1-when you floor it or 2-when you let off of the gas? If it smokes when you hit the gas it will more an likely be your piston rings. If it smokes when you let off of the gas pedal it will be your valve guide seals.
Old Oct 9, 2002 | 03:06 PM
Nighthawk GS-R's Avatar
New User
yep what he said.......
Old Oct 9, 2002 | 05:16 PM
piatl7il77's Avatar
Default Re: help! burning oil bad? (It's Blue)
yeah you better get that checked out
Old Oct 9, 2002 | 06:45 PM
3rdGteg's Avatar
Default Re: help! burning oil bad? (piatl7il77)
No way for sure to distinguish between the rings and seals unless you get that compression and leakdown test results.
Old Oct 9, 2002 | 07:47 PM
mickey513's Avatar
Since it's a 2001, bring it back to the dealership and tell them about your oil burning problem. Your car should be still under warranty, so they should fix it if they find something wrong. Also, do not tell them you are running synthetic oil, just tell them it's regular conventional oil. Some dealers will use all sorts of gimmicks/tricks to deny warranty.
Sounds like the car WAS NOT broken it right during the broke in period............
[Modified by mickey513, 6:27 AM 10/16/2002]
Old Oct 9, 2002 | 08:51 PM
Gong Show's Avatar
Old Oct 9, 2002 | 08:56 PM
John-GSR's Avatar
Default Re: help! burning oil bad? (mickey513)
Good advice. I was curious to know though, but why would a ring or valve stem seal go out on a new car already? Any ideas...
[Modified by John-GSR, 5:57 AM 10/10/2002]
Old Oct 9, 2002 | 09:12 PM
Gong Show's Avatar
Default Re: help! burning oil bad? (John-GSR)
Yeah, that was really good advice.
Someone cold have been beating the hell out of the car if it got it used.
Old Oct 14, 2002 | 10:01 PM
Vertigo's Avatar
Default Re: help! burning oil bad? (GONG SHOW)
A compresson test did not help me. It will only tell you if you have severe piston damage. I had two pistons with shattered rings and the compression was normal. Grab a helms and take it apart. See it for yourself.
Old Oct 14, 2002 | 10:07 PM
iH8RICERZ's Avatar
use 10w30...also check the oil filter/drain plug to see if anyoil is leeking from there
Old Oct 15, 2002 | 02:49 AM
lilxvtecxpwr's Avatar
Default Re: help! burning oil bad? (iH8RICERZ)
damn 2001 and bad ring(s) already?
Old Oct 15, 2002 | 05:07 AM
JDiMageDC2's Avatar
Hondas tend to burn a little oil when you use synthetic. Especially when you switch over to synthetic. Mobil 1 synthetic is good oil for your car, its just gonna burn a bit. I noticed my GSR was burning about 0.5-0.75 quart between changes, o I started monitoring it, regulating it. Your gonna deal with this using syn oil in a hond. Ive seen this with alot of hondas. As far as the smoke is concerned, you may have bigger problems.
Old Oct 15, 2002 | 05:02 PM
neof69's Avatar
Welcome to the world of HOnda Engines. My B16A3 loves to drink her oil. She needs a re-build.
Old Oct 15, 2002 | 07:28 PM
The_Oz's Avatar
Default Re: help! burning oil bad? (GSRTUNR)
Synth. oils burns in Hondas......really? How so?
Oz
Old Oct 15, 2002 | 07:36 PM
stumpyf4's Avatar
Default Re: help! burning oil bad? (The_Oz)
My GS-R with 80000km loved to 'use' Mobil 5w30, about 1 litre every 2000kms. No blue smoke, no leaks... just consumed it. I switched to Mobil 10W30 and still some usage. Now have gone to Castrol Syntec 10w30 and no usage of oil... 5000km oil change and 4 litres come out. Try using another brand of oil.
Marty.
Old Oct 15, 2002 | 09:29 PM
mickey513's Avatar
Default Re: help! burning oil bad? (stumpyf4)
Yup, I have seen a lot of people on this board with this "mysterious" oil burning problem when running Mobil 1....
19integra94
Dec 26, 2008 01:51 PM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
d8168055
Nov 23, 2002 07:06 PM
PY2KITR1060
May 4, 2002 01:30 PM
