Sooooo... I pulled the valve cover on my new GSR swap......
Old Feb 6, 2012 | 11:59 AM
Gofastturnleft's Avatar
Default Sooooo... I pulled the valve cover on my new GSR swap......
I have had this swap for almost a year now. The motor has not been ran much but has been started once in awhile. I got the motor new with only 900 miles on it. I am getting ready to start getting the car together. I was messing around to day in the garage and pulled the valve cover. I found a white sludge all thru the head. Please tell me this is just moister!!!!!!!!!!!!
Old Feb 6, 2012 | 12:02 PM
Wrona's Avatar
Default Re: Sooooo... I pulled the valve cover on my new GSR swap......
drain the oil check if there is anything brown in the coolant and do a compression test best way to tell sure looks like blown headgasket
Old Feb 6, 2012 | 12:15 PM
Thats what i was afraid of Oil still is clean. But i think from sitting so long the head gasket got messed up. I had an oil leak from the gasket. then once I started the car and let it run a few times it went away
Old Feb 6, 2012 | 12:48 PM
kyden's Avatar
it's not good just to let the car idle. if you're gonna start it, take it for a drive.
Old Feb 6, 2012 | 01:14 PM
Yeah i am seeing that now. I really cant drive the car because it is winter here in Pittsburgh and the salt is everywhere on the roads right now. I just pressure tested the coolant and is holding fine. Think its just moister build up.
Old Feb 6, 2012 | 01:37 PM
pityocamptes's Avatar
Moisture...
Old Feb 6, 2012 | 02:01 PM
hannslebo's Avatar
https://honda-tech.com/forums/showth...2876381&page=3
Read this...believe it's just moisture/condensation...
Old Feb 6, 2012 | 02:14 PM
NVturbo's Avatar
O.G. triple O.G.
If the car is parked outside in the elements, more than likely it's moisture due to limited usage.
Old Feb 6, 2012 | 04:40 PM
yeah the car is kinda a sad story it sat outside for 9 month thru the winter after the gsr. I recently just purchased a garage from the city to keep and build the car in. I will be getting it wired for electric soon so i will have heat in it. SO my civic will be nice and warm in the winters
Old Feb 7, 2012 | 03:24 PM
Cleaned off all the white gunk and put the valve cover and started praying my head dosnt rust!!!!!!!!!
Old Feb 7, 2012 | 03:31 PM
lazlong's Avatar
^^ Is that really a ground strap bolted to the header?
Old Feb 7, 2012 | 03:44 PM
grumblemarc's Avatar
The Grumpiest
Wow.
Old Feb 7, 2012 | 04:57 PM
Wrona's Avatar
Originally Posted by grumblemarc
Wow.
X2
Old Feb 7, 2012 | 05:30 PM
no lol Im pulling the motor soon so i didnt attach it again. Its just hanging there
Old Feb 7, 2012 | 07:47 PM
Cap'N Chronic's Avatar
Wow that is some nasty stuff. I had some white sludge forming around the PCV valve on my saturn due to a bad valve cover gasket, but nothing like that!
Old Feb 7, 2012 | 08:22 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Your aluminum head isn't going to rust. Neither are the cams that are covered in oil. Just start the car every now and then. Change that oil out.
Yuta
Dec 12, 2015 05:27 PM
TiNuts
Jan 17, 2013 05:25 PM
90CivicDaily
12
May 4, 2008 10:12 AM
DJNauTicz
Apr 11, 2007 10:43 PM
AGPSuperstar
Feb 17, 2003 12:15 PM
