Soon to be buying new motor... Leak down test better? Or compression test?
Old Feb 6, 2012 | 07:44 AM
t-town_ep's Avatar
Default Soon to be buying new motor... Leak down test better? Or compression test?
So I'm kind of torn here, I plan on buying a d16a6 motor soon from a local guy. In order to find out if the motor is still good, would it be better to do a compression test? or a leak down test? motor is out of the car. A compression test would be easier, but which would show me what i need to know? ex. low compression in cylinder and such.
thanks in advanced,
Lee
Old Feb 6, 2012 | 07:48 AM
killerken25's Avatar
Default Re: Soon to be buying new motor... Leak down test better? Or compression test?
better off doing a leak down test. because some leaks are fairly easy to repair depending on what it is thats leaking. if you do a compression test you will only see how much it is leaking and how fast. Stick to the leak down test.
Old Feb 6, 2012 | 09:24 PM
t-town_ep's Avatar
Do the local auto stores rent leak down testers? If not where can i get one for a decent price?
katoeh2o
Jan 9, 2008 11:49 AM
itr590
Nov 30, 2007 03:28 PM
Got_soy
28
Aug 8, 2005 12:49 PM
Propulsion
Jun 5, 2002 11:48 PM
