Enkei Rpf1 16x8 +38
Can you tell my how they fit under Integra Type R 1999?
Do I need do roll my finders and buy camber kit to let them fit without rubbing?
Post pictures if you have some
Since you're very interested in having a 16x8 wheel, I'll put it like this...
You won't be able to fit an 8" wide wheel under the car using proper sized tires, without doing some sort of fender rolling or running negative camber. This is regardless of the offset.
I think you could, at factory height only. The issue might be with knuckle clearance. Won't look very good though.
Oh wow, I just picked the same size yesterday. I installed two of them on (right side only) when I was buying them and I did not rub at all with 225/45/16 tires. This was out in the burbs of Chicago so the roads were all smooth, but I did go up a few parking lot ramps. I haven't had the chance to put them all on yet because I'm still missing aftermarket lug nuts, hub centric rings but I'll update on how they are.
the all out kid
Suspension & Brakes
Jan 31, 2009 10:07 AM
