Can't get cruise control to work after reinstall
Old Feb 6, 2012 | 07:21 AM
goldenmustache's Avatar
Default Can't get cruise control to work after reinstall
I removed cruise control from my em1 while I was installing a nardi steering a few months ago, everything was functional at the time.
I removed the wheel and put everything back to stock but now cruise control won't work.
When I activate it the green cluster light comes on but the car just slows down, pressing set or reset doesn't do anything either.
It was so straight forward to remove it and now put back together, I'm confused as to what is wrong or where to even start.
Old Feb 6, 2012 | 04:48 PM
rickkane's Avatar
Default Re: Can't get cruise control to work after reinstall
The cluster light comes on when you push set/resume or when you hit the main cruise "on" button?
Old Feb 6, 2012 | 04:55 PM
CTRjesse's Avatar
I have the same problem, my dash light doesnt come on when the cruise button is on
Old Feb 6, 2012 | 05:02 PM
Former User's Avatar
Do you also have an EM1?
Old Feb 6, 2012 | 05:07 PM
Any CEL codes?
Did you plug in the CC switches on the brake and clutch pedals?
Old Feb 6, 2012 | 05:42 PM
CTRjesse's Avatar
@ RonJ - yea i also have an em1
Old Feb 6, 2012 | 05:46 PM
By dash light, do you mean the CC light in the cluster or the light in the button to the left of the steering wheel?
Old Feb 6, 2012 | 05:51 PM
CTRjesse's Avatar
yea cc light in the cluster doesnt come on at all
Old Feb 6, 2012 | 05:53 PM
Does the button light turn on when pressed? And can we assume that CC doesn't work?
Old Feb 6, 2012 | 06:18 PM
apexi_rsx's Avatar
are all vacuum lines and throttle cables hooked up correctly? was anything unplugged to the cc? are you running a stock throttle body?
zmss56
Honda Civic (2001 - 2005)
Dec 13, 2012 06:32 PM
wingstogo44
Nov 29, 2007 09:25 AM
Kamikaze
Mar 9, 2007 11:14 AM
Elvis1977
Jan 13, 2004 10:52 AM
HuskerHybrid
Jan 16, 2003 04:58 PM
