5th gear died while driving
Old Feb 6, 2012 | 07:03 AM
SkiLLzWheeLz's Avatar
Icon2 5th gear died while driving
Was cruising home earlier down the highway about 70mph and 5th gear just went out. The shifter stayed in place but the tranny basically went into neutral. I didnt hear any noises or anything. Had to drive it home in 4th and had no more luck with fifth on a few extra tries. Transmission has always shifted perfect with no grinds and I drive it easy.
91 Civic Sedan DX w/ D15b vtec
Any ideas?
Old Feb 6, 2012 | 07:35 AM
90civic-ZC's Avatar
Default Re: 5th gear died while driving
shifting linkages loose?
Old Feb 6, 2012 | 07:54 AM
No everything is tight. The other gears work fine.
Old Feb 6, 2012 | 08:02 AM
killerken25's Avatar
if you put the car in 5th and let off the clutch does it stall out?
Old Feb 6, 2012 | 09:32 AM
No it doesnt stall.....just acts as if its in neutral. The shifter goes all the way forward like its supposed to. All other gears work.
Old Feb 6, 2012 | 10:17 AM
24TEN's Avatar
PHANTOM MENACE
My guess would be the shift fork or something related specifically to it. 5th gear has it's own separate shift fork.
Old Feb 6, 2012 | 11:27 AM
Could that go bad while driving in gear? I never grind the gears.....that requires tranny removal right?
d16efsedan
16
Nov 29, 2016 09:35 PM
si_ek
May 22, 2008 07:43 AM
eric416
Jun 23, 2006 02:10 PM
vc
Dec 22, 2005 06:58 PM
Rod.
Nov 11, 2004 09:05 PM
