Q45 TB adapter plate and remote map mount
Old Feb 6, 2012 | 01:51 AM
Zer0_SpeedWorks's Avatar
Default Q45 TB adapter plate and remote map mount
Here is my problem.
Currently I have a 76mm blox billet TB (Honda bolt pattern) on my car with Magnus intake manifold.
It's been leaking so bad in the bearing/bushing shaft area.
The thing is my Magnus intake is also drilled in Honda bolt pattern and my map sensor is TB mounted (Omni map).
Now my quick (cheap) fix is to swap it out and go Q45 TB on my intake and have a remote map mount.
Now my question is where to find the right adapter plate (Honda bolt to Q45 bolt pattern)?
I don't want to cut my Magnus' TB plate and weld a new one or drill another set of holes in it for the Q45 cause it might cause leaks.
Another thing is a remote map mount
Here is a quick google image
*credits to the owner
Any help would be great on where to find or buy these things?
Old Feb 7, 2012 | 07:07 PM
ihaterust's Avatar
Default Re: Q45 TB adapter plate and remote map mount
just connect the vaccuum hose directly onto the map sensor. you dont need that stupid adapter flange. also you could just plugs the honda holes in the magnus intake and drill new ones for whatever application you want.
now give me my internets please.
H22EG'z
Sep 22, 2009 06:52 PM
HybridKOOP
Oct 16, 2008 07:58 PM
da9blk1
Jan 16, 2008 05:04 AM
2phast
Jun 16, 2005 07:53 PM
handa
Jun 29, 2004 11:27 PM
