ITR LSD INTO LS TRANNY HELP???
Old Feb 5, 2012 | 08:17 PM
MShonda's Avatar
Default ITR LSD INTO LS TRANNY HELP???
okay i just got a s80 lsd itr tranny for next to nothing.
2nd and 5th/reverse gears are gone. i bought it for the lsd.
my question is: Is the factory itr lsd a direct drop into the ls tranny..
if not what has to be done. also what do i have to do to make the 4.7 fd work with the ls tranny. i know hardly anything about trannys so any help is appreciated
thanks
Old Feb 6, 2012 | 05:19 AM
MR.johnson's Avatar
Default Re: ITR LSD INTO LS TRANNY HELP???
You need to use the itr or gsr final drive. So use your itr ring and counter with your ls gear stack.
Old Feb 6, 2012 | 11:48 AM
DA93teg87's Avatar
Correct me if I'm wrong, but don't you have to shave the ribs on The trans for the lsd to fit?
Old Feb 6, 2012 | 12:01 PM
MShonda's Avatar
I have no idea.. I haven't broken down my ls trans yet just the itr... Of that's the case I could just swap all the internals over to the itr case
Old Feb 6, 2012 | 12:45 PM
MR.johnson's Avatar
All hydro cases will work.
Old Feb 6, 2012 | 08:42 PM
MShonda's Avatar
Okay im a newb at trannys..
what exactly has to be swapped over.. you say counter and i say i have no idea what that is. do you have any pics or could describe what each thing is better.
thanks
Old Feb 7, 2012 | 03:48 AM
MR.johnson's Avatar
Look up final drive swap. It's the ring gear and counter shaft.
Old Mar 1, 2012 | 08:13 AM
MShonda's Avatar
okay are the s80 ls countershafts the same as the countershaft in a jdm itr trans... basically will everything from my ls countershaft swap over to the itr countershaft?
Old Mar 2, 2012 | 03:46 AM
MR.johnson's Avatar
Your gear stack will fit on the itr shaft.
Old Mar 3, 2012 | 05:14 AM
94EG8's Avatar
Seagull Management
Correct.
No, all hydro cases are the same. YS1 cable trannys you have to grind down the ribs when using an LSD.
Old Mar 4, 2012 | 09:43 PM
h22apwrd95's Avatar
Just working from memory here, but you will also have to put the 1st gear from the ITR C-shaft in as well. I remember it being a different internal size on the JDM ITR C-shaft. If this is not a JDM ITR trans, and it is just a standard 4.4 C-shaft, and you will not have to worry about that.
Old Mar 6, 2012 | 07:02 PM
fourthgenhatchB17's Avatar
Nothing to do w/ original post but I'll chime in on this and say mixing a '97 spec LSD and YS1 require no mods, I know for a fact b/c I've done it. But I have read that before...maybe the '98 and higher LSD/ring gear is what requires the need for clearancing?
Mini_Filip
Transmission & Drivetrain
Jul 2, 2009 05:47 PM
precord96
Oct 27, 2003 04:25 PM
not so civic
Jun 1, 2003 08:48 AM
avividmemory
Apr 6, 2003 01:19 PM
p1ccoloz
Mar 15, 2003 08:21 PM
