ITR LSD INTO LS TRANNY HELP???
okay i just got a s80 lsd itr tranny for next to nothing.
2nd and 5th/reverse gears are gone. i bought it for the lsd. my question is: Is the factory itr lsd a direct drop into the ls tranny.. if not what has to be done. also what do i have to do to make the 4.7 fd work with the ls tranny. i know hardly anything about trannys so any help is appreciated thanks |
Re: ITR LSD INTO LS TRANNY HELP???
You need to use the itr or gsr final drive. So use your itr ring and counter with your ls gear stack.
Correct me if I'm wrong, but don't you have to shave the ribs on The trans for the lsd to fit?
I have no idea.. I haven't broken down my ls trans yet just the itr... Of that's the case I could just swap all the internals over to the itr case
All hydro cases will work.
Okay im a newb at trannys..
what exactly has to be swapped over.. you say counter and i say i have no idea what that is. do you have any pics or could describe what each thing is better. thanks |
Look up final drive swap. It's the ring gear and counter shaft.
okay are the s80 ls countershafts the same as the countershaft in a jdm itr trans... basically will everything from my ls countershaft swap over to the itr countershaft?
Your gear stack will fit on the itr shaft.
Originally Posted by MR.johnson
(Post 46810494)
Originally Posted by DA93teg87
(Post 46812495)
Just working from memory here, but you will also have to put the 1st gear from the ITR C-shaft in as well. I remember it being a different internal size on the JDM ITR C-shaft. If this is not a JDM ITR trans, and it is just a standard 4.4 C-shaft, and you will not have to worry about that.
Originally Posted by 94EG8
(Post 46964197)
No, all hydro cases are the same. YS1 cable trannys you have to grind down the ribs when using an LSD. |
