new 96 civic ex with a speaker and shifter problems
Old Feb 5, 2012 | 02:34 PM
deving916's Avatar
Default new 96 civic ex with a speaker and shifter problems
Hello all,
just picked up a 96 civic ex 2dr 5spd. There were no speakers in the car, but alot of sub/amp wiring (which was garbage).
I bought some sony 6x9 speakers for the back and 5.25s for the front. I got the backs in tonight, but didn't have any sound.
Which is the negative and positive wires? Also, in the front there is a 'clip' which I need to splice into but it has 4 wires so which do I need to splice?
Also, not music related, my shifter. There is alot of play when in gear, I can move the shifter alot left and right while in gear. Is this a bushing?
Thanks
Old Feb 5, 2012 | 02:55 PM
grumblemarc's Avatar
The Grumpiest
Default Re: new 96 civic ex with a speaker and shifter problems
Do not splice anything. Get a proper wiring adapter.
http://www.ebay.com/itm/HONDA-ACURA-...item4cfce16b2f
Old Feb 5, 2012 | 02:58 PM
deving916's Avatar
not for the radio, for the speakers.
Old Feb 5, 2012 | 03:03 PM
The Grumpiest
The plug for the radio means the speaker leads also. If the PO didn't totally hack all the wires then use the adapter. If he did then you have a lot of wires to start tracing and maybe rewiring.
Old Feb 5, 2012 | 03:29 PM
deving916's Avatar
alright Ill have to check and see. I tried to take the radio out, but it wouldnt budge.
Any advice on removing HU from 96 civic?
I had like almost every panel off, but it seemed pretty solid in there.
Old Feb 5, 2012 | 03:33 PM
The Grumpiest
http://www.installdr.com/installdocs/honda/civic.asp
Old Feb 5, 2012 | 03:47 PM
deving916's Avatar
okay thanks, i'll check and see if they used a proper harness for the radio.
If they did and thats NOT the case, then which wires do I need to splice to put the speakers in?
I have the rears in, but I didn't get any sound to them.
The front have a clip which has 4 wires though
Old Feb 5, 2012 | 03:50 PM
The Grumpiest
I don't know what you're talking about when you say it has a 4 wire clip. All the power and speaker wires run through that one plug under the dash.
Old Feb 5, 2012 | 03:57 PM
deving916's Avatar
I took the cover off the door panel where the speaker is and there was a clip that had 4 wires coming out of it.
Old Feb 5, 2012 | 04:01 PM
The Grumpiest
Don't really care about what's in the door. Trace the colors of the wires at the main plug to the doors and rear deck.
Old Feb 5, 2012 | 04:10 PM
98civdx's Avatar
Master Detailer
You said it have amps/lots of wires? Did it have a 4 channel amp??
You will need to check the HU and make sure the internal amp is turned on, if it has the ability to turn it off, if that isn't it, insure the wires going to the HU are connected.
I know I'll get **** for it, but on my car I just cut those speaker plugs off. They're for the OEM speakers, and wont work with aftermarket speakers.
You either need to cut them off, or buy the plugs.
DO NOT CUT the hu's plugs off. Hopefully, it hasn't already been done.
Old Feb 5, 2012 | 04:12 PM
The Grumpiest
A lot of people aren't aware that yOu can get adapters for the speaker plugs too. No need to cut anything.
Old Feb 5, 2012 | 04:16 PM
98civdx's Avatar
Master Detailer
I was aware of them, but again, being an impaitet 18 yr old I didn't want to wait.
But, i don't even use the factory wires anymore.
Old Feb 5, 2012 | 04:17 PM
deving916's Avatar
the PO had a billion wires, including 2 HUGE power wires run through the engine bay hooked up to a circuit break type switch that you'd see in a house. I mean the kid must of been a complete idiot with wiring. I pulled out telephone wires too it was just a mess.
Ill definitely take my HU out tomorrow and check all the wires and such. I thought they connnected through the doors since my car (00 ex) they did.
What about the rears? They only had 2 wires hanging on each side and I connected the speakers (tried both wires since I didnt know which was pos/neg) and I still got nothing
Old Feb 5, 2012 | 04:18 PM
The Grumpiest
Sounds like he hacked up a lot.
Old Feb 5, 2012 | 04:23 PM
98civdx's Avatar
Master Detailer
I hate when I see that. All you need is one solid power wire, to a disturbition block.
Regardless, pull the HU and inspect the connections.
There is a plug behind the fender, door harness, to dash harness.
You should only have 2 wires per side, +/-. However with normal speakers it doesn't really matter if you switch them around.
You need to make sure those wires are even getting power. (HU)
About $20 for the car.
http://www.ebay.com/itm/NEW-METRA-72...item2562291551
Old Feb 5, 2012 | 04:37 PM
deving916's Avatar
yeah those look like they would plug in perfectly.
Any info for the shifter?
Old Feb 5, 2012 | 04:42 PM
The Grumpiest
Energy Suspension shifter bushings.
Old Feb 5, 2012 | 04:47 PM
deving916's Avatar
How do I know if I need a shifter bushing though?
When I'm in gear or even in neutral, I can move the shifter significantly right/left.
When I'm in gear I can move it like I'm in neutral? They seem good, just want to order the correct item thats all.
@CiviDx are those speaker connectors universal? They don't say anything about being model specific
Old Feb 5, 2012 | 04:50 PM
The Grumpiest
Get under the car and check them.
Old Feb 5, 2012 | 05:04 PM
98civdx's Avatar
Master Detailer
They should, the plug looks fine.
However, if it put you at ease, go to a stereo shop. it will cost more, but if they dont work you can return them.
Old Feb 5, 2012 | 05:28 PM
deving916's Avatar
yeah ill probably end up doing that, i'm another impatient 19yr old lolz
Old Feb 5, 2012 | 07:44 PM
jbpnoman's Avatar
You know you need new shifter bushings because what you're describing PERFECTLY matches the symptoms of shot shifter bushings. Get some from BWR. Cheaper than Energy, and they're the exact same thing. I don't mean "kind of" the exact same thing, I mean literally the EXACT SAME THING, from the same manufacturing plant.
Old Feb 6, 2012 | 02:06 PM
deving916's Avatar
got the radio out today, such a pain.
but it looks like the harness from the radio to the civic was shotty so i'm going to buy a new one tomorrow and re-wire it.
Old Feb 6, 2012 | 02:11 PM
deving916's Avatar
my dome light in my car turns on if i move the switch, but not if the door is open and key is in (unless i move the the ALWAYS on positon)
is this radio related too?
