Clutch issue?
The pedal vibrates in neutral and while in gear while I drive.
I believe that it is the original clutch, and it has 84k miles on it.
I will make sure to double check if the clutch stops vibrating after the car heats, up, thanks!
I'm a beginner so I try to rest, not apply ANY pressure whatsoever on the clutch while I'm driving just in case I need to suddenly stop because of careless drivers. I can feel it vibrating under my shoes.
Does the rest of the car seem to vibrate in general? Or are you only feeling it through the pedal?
You might just be feeling vibration from the engine. If it seems excessive I would check your motor mounts to make sure they're not torn. The mounts can get torn over time.
Also welcome to Honda-Tech
