Can someone fab me a b-series "low profile" PS bracket?
Grind the PS bracket bolt flange down a bit file it flat, grind half the head off that bolt and should fit.
what he said lol
what he said lol
Thanks for the suggestions, i was thinking of getting a M14 x 6mm spacer, then make a 2 pieces CNC aluminum to replace the bracket hehe... That would shave like 1lb and look prettier.
But I think going countersink + this bolt: http://www.onlinefasteners.com.au/on...ners/node/1079
Should get the job done and save some money haha...
@LKSi where did you get your M14 countersunk bolt? The site i found don't ship internationally. And I've been trying to find other place, none of them sells it (not on ebay either)
That sounds so shitty. LST.
Mill the face down and use a shorter bolt with a countersunk head. That you can do at home if you are on a super budget with a grinder and you put the part in a drill press to countersink.
Anyone know where to get a M14 countersunk bolt? RenoDepot/HomeDepot/Rona here don't sell such a big bolt here (they have M14 but is not countersunk)
Basically need M14 x 45mm
You don't need to counter sink that, just take a grinder and notch the "bulge" flat with the flange. Will fit just fine, might even be able to use the same bolt.
the soL that could
Sep 12, 2011 06:19 AM
117
16
Apr 2, 2009 10:18 PM
albert butterbikini
Jun 30, 2001 02:54 PM
