DA master cylinder
Old Feb 4, 2012 | 01:47 PM
theEFkid's Avatar
Default DA master cylinder
is anyone on here running a DA master cylinder while still running the drum brakes and stock porportioning valve? my DDs stock MC is on its way out and i have a DA one from another car i stripped and i wanted to know if anyone was running a setup like that and had any problems
Old Feb 4, 2012 | 01:51 PM
TeamRedline89Hatch's Avatar
Default Re: DA master cylinder
You will have to use the DA brake booster with the DA MC. I am using the 91 EX MC (15/16") on my std hatch, stock prop and drums. Works just fine.
Old Feb 4, 2012 | 01:59 PM
theEFkid's Avatar
cool, thanks its nice to ask a question and actually have it ansewered on here for once
Old Feb 4, 2012 | 02:42 PM
~sp33~'s Avatar
EFB055
You can also use any booster with the same bolt pattern for the master cylinder. I'm using a DA master with a DC booster.
Old Feb 5, 2012 | 07:41 AM
MikeFabRex's Avatar
This is correct!
It's best to leave your exisiting proportion valve for right now when swapping in the DA master cylinder, & brake booster. When you decide to go rear disc brakes, then you'll want to swap in the Integra 4040 proportion valve.
Old Feb 13, 2012 | 08:22 PM
DADLIHonda24122's Avatar
How do you know the MC is going? does your pedal go randomly soft?
Old Feb 13, 2012 | 10:50 PM
~sp33~'s Avatar
EFB055
The brake pedal will sink/wont hold pressure.
zuptidi
Oct 30, 2014 04:18 PM
0NE600
14
Sep 12, 2011 03:38 AM
sohcrx91331
Sep 8, 2009 03:50 PM
eskerley
Jan 23, 2008 03:24 PM
duh blacksheep
Apr 24, 2005 11:09 AM
