89 hatch with suspension/braking issue
Old Feb 4, 2012 | 09:26 AM
blank879's Avatar
Default 89 hatch with suspension/braking issue
whats up HT i cant figure this out so i came here.
car is a 89 dx hatch
obd1
b20b
when i come to a light and hit the brakes my right front wheel is jamming in (negative camber) and grinding like no tomorrow. when i get back on the gas it goes back to normal and i dont hear any noise, i can literally feel something shifting.
the car needs bushings all the way around, i know that. ive replaced the struts, springs, outer tie rods (now one is missing the bushing and cover wtf) and camber kit on the whole car.
rotors maybe? maybe the wheel bearing? the assembly has very very little play up and down (seen much much worse still driving).
Old Feb 4, 2012 | 12:49 PM
v4lu3s's Avatar
RTFM
Default Re: 89 hatch with suspension/braking issue
sounds like you need to start replacing the parts you KNOW are worn out, bad bushings that allow a lot of suspension movement can do a lot of bad things...btw when you replaced all that other stuff did you get an alignment?
Old Feb 4, 2012 | 12:51 PM
.Manny.'s Avatar
Touching My Member
Jack the car up, set on jackstands and take a look. We can't diagnose broken, missing, or loose suspension parts over the internet.
Old Feb 4, 2012 | 02:44 PM
~sp33~'s Avatar
EFB055
Originally Posted by blank879
when i come to a light and hit the brakes my right front wheel is jamming in (negative camber) and grinding like no tomorrow. .
Do you have adjustable camber arms?
ac_attak
Aug 22, 2008 12:16 PM
CRXed
Suspension & Brakes
Jul 9, 2007 02:43 PM
2doorsMOthanU
Suspension & Brakes
Feb 14, 2006 07:33 PM
I8ayellowcrayon
Sep 7, 2003 11:20 AM
brbHPR
Aug 26, 2003 08:44 PM
