stock valve train on turbo build
Old Feb 4, 2012 | 04:58 AM
BoostedEM1!'s Avatar
Default stock valve train on turbo build
I am getting ready to dyno my car next week and considered throwing in some itr or skunk tuner 1 cams potentially blox a cams. My question is with having stick valve train and adding this style of cam are the risks high for failure on valve train. I understand not reving past 8000 rpms is the deal but the v Tec crossover will yield more boost on the aftermarket compared to my stock hsrd cam.
Old Feb 4, 2012 | 06:12 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: stock valve train on turbo build
Questions are typically followed by a "?" mark.
This "question" comes up at least one time a day now; so I wil keep this short and sweet.
If you aren't going to run the appropriate valvetrain then DO NOT DO THE CAMSHAFT SWAP. It's that simple really...
RPMs aren't the only thing you look at when choosing what valve springs you should run.
Old Feb 4, 2012 | 10:14 AM
DirtyDA9's Avatar
Uhhhh... What?...
Old Feb 4, 2012 | 03:04 PM
Charlie Moua's Avatar
valvespring is something i greatly overlooked when i did my "simple" turbo gsr build.
But after talking to my engine builder and tuner they told me how stiffer springs will allow your engine to make more power under boost as they can close/open slightly faster.
If you think about it your having a lot more psi per cylinder and that PSI does affect how stock valvesprings will open/close.
I've order some rocketmotorsports snapfit valvesprings which are about $160 and come with new viton valve seals. These are designed to work with stock seats & retainers.
Their spring pressure are more than ITR dual valve springs but not overkill like some of the heavy dudy springs. I've yet to find a better return on your money than these VS.
If your not shooting for close to 400whp or over, i would stick with GSR cams.
BUT when in talks with Evan he highly reccomends tunerseries cause they don't cause too much wear on rockers but also provide nice gains over gsr/itr cams.
If you want to sell those cams lmk.
Old Feb 4, 2012 | 03:11 PM
Thanks bro I though about using some supertech springs and retainers but I don't want to have to pull the head so will stock valves be good for 400 Hp
Old Feb 4, 2012 | 03:58 PM
stock valves are fine....
but aren't you talking about valve springs?
Old Feb 4, 2012 | 04:10 PM
sanman000719's Avatar
gsr cams have been over 700whp many many times and valve train as well and about to again in my car
Old Feb 4, 2012 | 04:30 PM
DirtyDA9's Avatar
Stock valves are fine. And nothing wrong with supertech springs for what you are looking for.
Old Feb 4, 2012 | 04:31 PM
thats what i forgot to mention is im on supertech springs other than that its a stock p72 head
alcarp
Mar 4, 2010 05:15 PM
krazeenoy
Jun 12, 2007 06:26 PM
Home Wrecker
Aug 18, 2006 05:50 AM
jonathan13
Jul 6, 2006 01:45 AM
tek_civic
Jul 7, 2003 10:52 AM
