Gone through 2 turbos already, help me diagnose!
Old Feb 3, 2012 | 08:25 PM
sde780's Avatar
Default Gone through 2 turbos already, help me diagnose!
I'm running a built D16Y8 with 75.5mm Vitaras, custom length FJ dist rods.
New:
OEM oil pump no shim or port
Clevite STD bearings (.002" clearance)
Rods, pistons, rings, gaskets, etc.
Micropolished and chamfered crank
Revving to 7200rpm
Stock head
I made 235whp at 8psi for 12,000 miles on the stock motor, then pulled it for my built motor. Nothing was broken, I just took advantage of my Thanksgiving break to get the motor in. Used the following turbo for 12k miles with no issues.
1st setup: T3 60 trim .60/.63ar from a Thunderbird
Made 300whp at 20 psi, 2 days later I was boosting fine when I hear a loud whining sound and no more boost. Compressor nut came off, major major side-side and in-out shaftplay.
2nd setup: Sent that T3 60 trim out to mhamrick to get rebuilt, he upgraded the compressor housing to a T4 with a 44 trim compressor. New CHRA, stage 1 turbine, and was balanced. Installed a new -3an feed line and the appropriate adapters. Kept it at 12psi following mhamrick's advice, boosted great. 1 day later, I'm at 12 psi and it suddenly drops to 8 psi. I pull over immediately, notice that there is a rattling noise at idle. So I poke around and found the turbo compressor was making contact with the compressor housing. 5 hours before this I checked the shaftplay and there was very little side to side, no in/out at all. Now it has noticeable in/out, very little side to side shaftplay.
The drain is above oil level, fairly straight with a 90* bend at the fitting. I had no issues with the drain setup for 12k miles. Oil feed is new. I pulled the drain and let it idle for a couple seconds, a good bit of oil came out, telling me the feed is not clogged.
Freshly changed oil both times the turbo blew, I just can't figure out why I keep blowing turbos. The car's been down for over a month now, and being my DD I need to fix it ASAP.
Any suggestions?
EDIT: No restrictor with the new -3an line.
Old Feb 3, 2012 | 09:43 PM
MiraiZ's Avatar
Default Re: Gone through 2 turbos already, help me diagnose!
Where on the oil pan is the return feed?
could be that the turbo had other issues...should buy a new one, otherwise you'll wind up spending more on rebuilds and repairs
Old Feb 3, 2012 | 10:23 PM
sde780's Avatar
Right above where it starts getting deeper, as high as I could put it. I pulled the drain off and no oil came out.
Any site you recommend for buying new? I'm just curious, shopping around a t3/t4 50 trim is $700
Old Feb 4, 2012 | 07:09 AM
prsxr88's Avatar
post some pictures of what you have. turbo feed source. and entrance into the turbo, the same with the drain. although it doesn't sound like an oiling problem.
from what you posted it sounds like a dud turbo.
Old Feb 4, 2012 | 07:21 AM
LightningTeg's Avatar
Community Builder
Send it to TheShodan and im sure he'll be able to tell you what happened or if the turbo is salvageable or not.
Old Feb 4, 2012 | 08:02 AM
sde780's Avatar
Here is my drain
Old Feb 4, 2012 | 08:20 AM
Whiterice-gsr's Avatar
your drain looks fine, im leaning towards bad turbo, your problems dont sound like the usual over oiling or oil starvation problems. i would buy a new turbo, if u want a cheap replacemnet slap on a chinese turbo to get u up and running while u diagnose the issue with this one or do some research on replacing it. theshodan can help u diagnose, rebuild or replace.
Old Sep 14, 2012 | 08:29 AM
sde780's Avatar
Just to update, it turns out the "turbo rebuilder" was a scammer and the reason why I went through so many turbo problems. I bought a Garrett T3/T04e 50 trim and with the exact same feed/drain, it's lasted me for almost a year now
Old Sep 14, 2012 | 11:29 AM
wantboost's Avatar
Who is Mr Robot?
I spy an eBay compressor housing....
Old Sep 14, 2012 | 12:03 PM
keith1054's Avatar
How well was the turbo balanced as part of the rebuild?
Were any of the fins damaged as a result of housing contact?
Old Sep 14, 2012 | 04:55 PM
Rollo Lawson's Avatar
u need to recalibrate ur reading skills......
"1st setup: T3 60 trim .60/.63ar from a Thunderbird"
Old Sep 14, 2012 | 10:17 PM
EsotericImage's Avatar
Retired Moderator
whats your highest oil pressure reading at WOT and cold start up?
im thinking high oil pressure is blowing the seals
Old Sep 15, 2012 | 01:30 AM
wantboost's Avatar
Who is Mr Robot?
i know how to read... that pic was of the second setup when he went to a t4 based compressor side... i know what a garrett 60 trim t3 looks like, post useful information or **** off...
that picture is clearly of a t04e ebay compressor housing... not a garrett 60 trim t3 compressor housing.
if you pulled the return line and no oil came out then clearly you have an oil feed issue
Old Sep 15, 2012 | 05:16 AM
sde780's Avatar
No oil came out of the oil pan fitting, meaning it's not because my drain fitting is too low in the oil pan.
If you read carefully I said a good bit of oil comes out the turbo drain.
Problem is already solved, it was the bullshit "turbo rebuilder" scamming me...he actually had me send the turbo back and just kept it!
Old Sep 15, 2012 | 05:19 AM
sde780's Avatar
The rebuilder "sent it off to california" to get balanced...the rebuild took him 2 months so I don't know whether he actually did or not. Yes the compressor was completely chewed up.
Old Sep 15, 2012 | 08:37 AM
TKERacer619's Avatar
I was going to suggest getting a Garrett but looks like you already solved it the right way
boosted_D
Apr 1, 2012 09:27 AM
zexifiedlude
Nov 12, 2005 03:52 AM
frogscivic
Apr 21, 2003 06:58 AM
nitroedhx
Feb 12, 2003 08:55 PM
t04ef
Nov 18, 2001 03:13 AM
