94 honda accord ex headers installed
Old Feb 3, 2012 | 06:42 PM
portugueboy10's Avatar
Icon2 94 honda accord ex headers installed
i recently bought headers for my 94 honda accord ex, i was wondering if anyone knew how to install them???
Old Feb 3, 2012 | 07:54 PM
nus_dogg's Avatar
Default Re: 94 honda accord ex headers installed
It's pretty straight forward.
Undo the header heat shield, that'll expose you two some bolts that bolts the top half header to the head; undo those. Jack the car up and go underneath, undo three bolts that bolts the top of the header to the downpipe. Now you should be able to wiggle the top half out. Then go back underneath and undo the two catalytic converter bolts w/ springs. You can choose to unbolt the 02 sensor off the header/downpipe before you touch anything or after you got the header/pipe off, it's up to you.
Install is reverse of removal.
Old Feb 3, 2012 | 11:21 PM
MAD_MIKE's Avatar
MM Gruppe B
For clarification, the primary O2 sensor is installed in a separate ~4" 'middle' pipe before the catalyst. It is not attached to the manifold or down pipe on an EX model.
Part #7
Old Feb 4, 2012 | 04:11 PM
enriquez2000's Avatar
And if your header has 2 spots for o2 sensors an m18x1.5 pan plug will fill the useless spot up
Old Feb 6, 2012 | 04:49 PM
thanks guys, came out great!!
Benny Honda
Jun 14, 2017 05:49 PM
HondaDude94
Mar 5, 2007 08:43 AM
Sublime95
May 17, 2004 11:02 AM
Rukusmasta2
Feb 3, 2003 07:55 AM
hondarule
Oct 7, 2002 05:15 AM
