99 civic dx hatch brake light issue HELP
Old Feb 3, 2012 | 04:17 PM
Marvin1985's Avatar
Default 99 civic dx hatch brake light issue HELP
Just got it. All bulbs in tail lights work but the brake light doesn't work as in they light up with night time lights on but don't go bright when brake pedal is depressed. I replaced the bulbs, fuse is good, replaced brake light pedal switch and still NOTHING! What else could it be????
Old Feb 3, 2012 | 05:09 PM
Former User's Avatar
Default Re: 99 civic dx hatch brake light issue HELP
Does the high mount brake light work?
Does installed 15A hood fuse 52 have battery voltage to body ground at both of its top test tabs?
Old Feb 3, 2012 | 05:27 PM
Marvin1985's Avatar
High mount don't work either I'll check the other fuses you said.
Old Feb 4, 2012 | 11:19 AM
Marvin1985's Avatar
Issue fixed: problem was weird. My horn didn't work either so I popped the fuse panel in the engine bay to see the horn/stop light fuse not in place. I pushed the fuse down, checked the horn, was good, checked brake light and boom they worked. I almost took it to Honda to diagnose but stuck at it.
Old Feb 4, 2012 | 11:21 AM
Lesson: Always rule out the simple bonehead items first. Fuses are number 1 on the list of bonehead items.
hondalion
Aug 5, 2014 02:50 PM
90crxdxb16
12
Jun 8, 2012 05:15 PM
prelude_93vtec
Nov 26, 2007 01:57 PM
im done
Nov 12, 2004 08:52 PM
JdmLsPwr425
May 4, 2004 03:58 AM
