FS: GT4088R Turbo w/.81 Precision Housing ($550), .68 Housing
Email: filaraki99@msn.com
I'm selling a used Garrett GT4088R ball-bearing turbo with a Precision .81 undivided housing. Will also throw in a .68 Precision housing for an additional $85. This has been on my car since the turbo was new, with a total of about 6,000 miles on it. About 4,500 miles ago I was toying with various turbine housings and noticed that the turbine wheel inducer edges had some fraying, I presume from either a piece of ceramic coating or carbon going through the wheel right after it was installed. It has not show any ill effects as a result though, as I hit 16 psi before 4000rpms (on a 3L 2JZ) and the car was making well in excess of 600whp at 25 psi. Zero shaft play (hasn't increased at all over the time of use). Fraying is not visible unless the turbine housing is off, and hence is not visible in the pics. Only reason I'm selling it is that I'm now looking for more power. $550
schnell96
Mar 4, 2012 01:19 AM
kidkutz
Oct 6, 2002 03:33 PM
kidkutz
Sep 20, 2002 06:00 AM
