S/T sway bars
Old Oct 9, 2002 | 10:02 AM
mr2td's Avatar
New User
Default S/T sway bars
I just installed the Suspension Techniques rear sway bar on my 92 coupe, it turned the car into a whole different animal. It tends to oversteer a bit now which is pretty much what the rear sway bar SHOULD do.
Anyway, has anyone done just the rear, and then installed the front S/T bar later on? Can you comment on how much the front & rear bar improved handling versus just the rear? If the front bar makes as much of a difference as the rear, I'd buy it in a heartbeat.
Old Oct 9, 2002 | 10:41 AM
MyBigNut's Avatar
Default Re: S/T sway bars (mr2td)
Id like to hear this too.
Old Oct 9, 2002 | 10:43 AM
SOHCArchangel's Avatar
Default Re: S/T sway bars (MyBigNut1)
i have just the rear, the more oversteer the better, i just threw poly bushings on the front one
Old Oct 9, 2002 | 10:56 AM
mrnicolas's Avatar
Default Re: S/T sway bars (SOHCArchangel)
is your car a ex? I had a set of S/T sway bars, but my car is a lx. I did not quite unserstand the nstructions on drilling the lower control arms. Do you have pics of the new bar installed?
Old Oct 9, 2002 | 11:53 AM
vtec94's Avatar
New User
how much did it cost you? i'm referring to the front sway bar polyurethane bushing. and where did you get 'em? how hard was it to install 'em?
please advise!
thanks
Old Oct 9, 2002 | 12:22 PM
Default Re: S/T sway bars (vtec94)
oh boy
the bushings i got from energy suspension and the rear bar was 130 bucks + shipping, and it was easy and straightforeward to install, and yes i have an ex
Old Oct 9, 2002 | 01:22 PM
Accord94DX's Avatar
98 bucks shipped for ST rear bar and bushings, install was cake as I had a lift and airtools.
Old Oct 9, 2002 | 01:25 PM
D21X's Avatar
Default Re: S/T sway bars (Accord94DX)
whoa where did u get the ST bar and stuff for 98 shipped??????????
Old Oct 9, 2002 | 01:30 PM
Accord94DX's Avatar
Default Re: S/T sway bars (D21X)
my work (honda) . Check nopi, they are usually pretty cheap.
Old Oct 9, 2002 | 01:48 PM
briq4's Avatar
I have the set, and really wish I had just put the rear on first and saw how it felt. Handles much better than before, although it's not tail happy at all. My R was much easier to get the back end to swing out.
Old Oct 9, 2002 | 02:10 PM
D21X's Avatar
damn i wish i could get it for 98 shipped. i checked NOPI and they have it for $120 +shipping. anyone know where i can get it for cheaper?
Old Oct 9, 2002 | 02:29 PM
urbanlegend21's Avatar
New User
I bought just the rear bar and will never buy a front unless I go to some crazy high spring rate like 1200 lbs. I actually have loosened the front bar to get more oversteer in the car. It tends to plow to much on track and there is a definent tire wear issue with that plow after I get off the track.
don't worry about the front bar, but also be prepared for the car to snap quicker than before.
Old Oct 9, 2002 | 03:22 PM
mr2td's Avatar
New User
Default Re: S/T sway bars (mrnicolas)
The way I understood it, you will have to drill the rear trailing arms either way, even if you have an EX (mine is an EX, and I had to drill the holes.) I've seen people do it both ways, either using the existing hole from the stock rear sway bar, or being like me and drilling a new hole. The instructions say that you are supposed to drill a hole 1" forward of the existing stud. I drilled the hole - it wasn't that hard.
Note that even with my stock exhaust, the bar rubbed on the exhaust pipe. I cut a piece of heater hose and put it in between, it seems to be doing the job.
Old Oct 9, 2002 | 03:46 PM
vtec94's Avatar
New User
so what do i need to swap out the rubber bushing to the polyurethane bushing for the stock size front sway bar for 94 accord?
where can i get 'em? how much?
Old Oct 10, 2002 | 07:04 AM
Razor's Avatar
actually when i installed mine, i had to remove the axleback portion of my catback to gain clearance for the sway bar. the s/t rear sway bar was a pain, and i had to drill holes too even though i have an ex. from what i heard, adding a front sway bar will make the car feel neutral again, almost like stock. the rear sway bar only is much better IMO unless you absolutely hate oversteer.
Old Oct 10, 2002 | 07:16 AM
Gennady's Avatar
New User
Default Re: S/T sway bars (Razor)
Putting my car on stands took me 40 minutes, installing the bar took me 20. It was cake. The bushings can be bought from AutoZone or Pepboys.
Old Oct 10, 2002 | 06:23 PM
mr2td's Avatar
New User
Yeah. I was surprised how tight the bar was with my stock exhaust... I can't imagine how it would be with bigger piping in the way.
I am having fun with the rear sway bar - learning how to drive a little bit more agressively. it was a little scary in the rain at first, though!
Old Oct 10, 2002 | 07:21 PM
Razor's Avatar
the only thing that sucks is that when my car is on road with an angle ,my rear sway bar rubs against the piping of my catback and makes a loud rubbing noise. does anyone know something that i can do?
Old Oct 10, 2002 | 07:58 PM
Accord94DX's Avatar
wrap a piece of radiator hose over the offending piece of swaybar.
Old Oct 10, 2002 | 09:30 PM
Razor's Avatar
thanks for the tip mang
Old Oct 11, 2002 | 06:17 AM
Gennady's Avatar
New User
If you use the ST rear bar, I would recommend some custom piping.
Old Oct 11, 2002 | 08:50 AM
Razor's Avatar
Default Re: S/T sway bars (Wont be beat)
i dont feel like taking off my 600 dollar catback just for a sway bar, ill try the radiator hose trick.
Old Oct 11, 2002 | 08:52 AM
Gennady's Avatar
New User
I've got a radiator hose on mine. It just goes around the problem instead of fixing it.
Old Oct 11, 2002 | 08:58 AM
Accord94DX's Avatar
**** yeah. i have drugs and prostitutes to spend my money on, im not putting it towards creating a Sway bar friendly exhaust.....radiator hose plea.
Old Oct 13, 2002 | 07:58 PM
bmm89's Avatar
i thought rad hose, but then got worried that it might melt(unlikely) but just in case i wrapped exhaust wrap around the rubbing/clinking section
oh and notice how there is virtually no body roll
