Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Fender Bulge?
Old Feb 3, 2012 | 08:48 AM
oresama's Avatar
Icon2 Fender Bulge?
Saw this EK civic on speedhunters website and thought the fender bulge was genius.
Can anyone chime in on how this was possibly achieved?
Thanks in advance!
Full Article Here
Old Feb 3, 2012 | 08:57 AM
unusual71's Avatar
Default Re: Fender Bulge?
not difficult, be prepared for big gaps in the hood fitment though. can bend the fender mounts and slot the holes, or longer bolts w/spacers such as washers
Old Feb 3, 2012 | 08:59 AM
Egezzy's Avatar
Spongebrad Squarepants
Old Feb 3, 2012 | 09:19 AM
WhiteSlips's Avatar
All you have to do is put some spacers or stack washers up where the fender mounts under the door. You might have to trim the side skirt a little to allow the fender to push outward, but it shouldn't be hard at all.
Old Feb 3, 2012 | 10:04 AM
oresama's Avatar
Thanks unusual71, WhiteSlipsWithStickers for the insight. Might give this a try and see how it turns out. I am worried about the hood not being flush but we'll see how bad it really turns out.
Oh and egezzy.... wrong bulge lol.
Old Feb 3, 2012 | 11:21 AM
jdmspoonitr's Avatar
Lots of evo guys do this. Check on EvoM
Old Feb 3, 2012 | 11:31 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
that's funny, i had some left over hood spacers, and one day while sitting in the garage i stuck them in my fenders to space them out. definitely helped my rub issue.
function > fashion
Old Feb 4, 2012 | 01:28 PM
BuyBrakes.com's Avatar
I like this idea as well, people keep saying washers, but I am still not seeing how that would work. If you look where the fender bolts to the car in the engine bay, putting in washers would only raise the fender up, how do you get it to push out?
I would assume you notch the fender where the bolt goes through so that you can slide it to where you want it?
Old Feb 4, 2012 | 01:45 PM
The Destroyer's Avatar
I think they put washers near the door on both top and bottom, between fender and frame. Looks like the top furthest back fender bolt hole has been modified.
Old Feb 4, 2012 | 02:17 PM
you can loosen the bolts and pull the fender out, it'll make a larger gap between the fender and hood
Old Feb 5, 2012 | 10:10 PM
integlspwr2k's Avatar
Anyone have more details on this. I want to do this for my EK hatch!
Old Feb 6, 2012 | 01:32 AM
E-AT_me's Avatar
i ran washers at the bottom of the fender of my CRX for a while. was really diggin the looks, but i didn't need the gap so i took 'em back out.
Old Feb 7, 2012 | 06:56 AM
alphalanos's Avatar
mine looked like this for awhile when i only had the top bolts in
Old Feb 11, 2012 | 04:58 AM
exgr's Avatar
Homosexual by choice
You just need a longer bolt and spacer at the bottom point right in front of the door jams.
Old Feb 19, 2012 | 12:01 PM
jeremy5000's Avatar
I know a few BMW guys who do that to allow for more air flow... looks pretty sick IMO and supposedly is functional.
Old Feb 19, 2012 | 12:32 PM
Lo-Buck EF's Avatar
the purpose is to get the turbulent air in the fender well out.
Old Feb 26, 2012 | 07:53 PM
did mines this weekend.
please dont mind the missing lug nuts. i have my rays on their way.
Old Feb 27, 2012 | 07:59 PM
Evo guys do it to get a wider tire under the stock fender. For an FF Honda, it's pretty useless unless you plan on running larger than a 225. I can run a 225 under the stock fender with no rubbing with the proper offset wheel, so if it's just the look you are going after then it's kinda weaksauce if you ask me since the fitment looks kinda ghetto around the headlight.
They use a metal or carbon brackets with two holes for bolts to connect to span the original locations. The fitment around the headlight will be a bit off.
Old Feb 27, 2012 | 08:10 PM
Old Feb 28, 2012 | 06:45 AM
Yah no offense but when your wheels are narrow sunken battleship status on the stock fender, it really serves no purpose to push the fender out more. It's like rolling your fenders to fit a 15x7....
Old Feb 28, 2012 | 12:02 PM
low_and_slow
Paint and Body
Mar 25, 2010 07:39 PM
tom2000
Suspension & Brakes
Sep 11, 2009 01:41 AM
dayvid05
Aug 5, 2008 01:54 PM
