Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2005 pilot fob. Will it lose its programming?
Old Feb 3, 2012 | 07:45 AM
ezol's Avatar
Default 2005 pilot fob. Will it lose its programming?
My 2005 pilot fob housing was broken so I bought a shell online and took the guts from the old fob and put in the new and got the key cut. The car will crank over but it will not start. Will the fob lose its programming? I put new battery in and the led does not light up either. The batter was dead for about 6 months before I replaced it. Any ideas ? Thanks in advance for the help
Old Feb 4, 2012 | 05:53 PM
ricebike's Avatar
Default Re: 2005 pilot fob. Will it lose its programming?
if you had the key cut, did you also reprogrammed it for your vehicle?
did the seller gave you instructions on how to program it?
the following thread shows a small part called the immobilizer
no green light = maybe a dead battery
something similar to that key
source: http://forums.clubrsx.com/showthread.php?p=38872574
it shouldn't lose it's programming if you replaced the battery & still have the immobilizer chip in it
pause video at 2:17 and you'll see the immobilizer chip on the lower cover (right hand), bottom corner by the key
Old Feb 6, 2012 | 02:36 PM
ezol's Avatar
thanks for the info ricebike. that helped. i just cut the chip out of the old fob shell and installed it into the new one. didnt know the chip was located there. i thought it was built into the keyless syatem.
Old Feb 6, 2012 | 04:16 PM
ricebike's Avatar
did it worked? because i have no idea if that was the case
i was just googling for you
Old Feb 9, 2012 | 05:05 PM
ezol's Avatar
hey ricebike it worked. thanks for the help.
Old Feb 9, 2012 | 06:13 PM
ricebike's Avatar
thanks for the update... guess it wasn't the remote battery
Old Feb 27, 2012 | 10:17 AM
Soju1's Avatar
i replaced the battery on my remote and the green light still doesnt come on. any suggestions?
19Wagon91
Nov 18, 2018 11:29 AM
JasonST
Jul 15, 2018 03:29 AM
Mexan02
Jul 23, 2006 07:36 PM
311
Oct 23, 2002 05:19 AM
Johnny Gasparini
Sep 19, 2002 09:41 PM
