b16a2 94 Hatch Broken Coolant Bleeder Valve
Old Feb 2, 2012 | 06:27 PM
phoenixsage911's Avatar
Default b16a2 94 Hatch Broken Coolant Bleeder Valve
JDM b16a2 installed on a 94 Civic Hatch CX 60k
Someone has snapped the coolant bleeding valve from the "water outlet cover"?
Quick valid questions please:
Question 1: What is this part called for my b16a2? Where can I get it replaced? Is it easy to remove this assembly? I havent had a great look at it on the backside of the motor. Been dealing with 100 other things.
Question 2: I have the bleeding screw and the little housing it threads into. Can I glue , weld or attach this back onto the block? Looks to be the similar material as the engine. Cement block material stuff?
I temporarily have a screw lightly twisted into the hole.. Seems it holds the coolant under pressure.. I dont want to rely on it. I keep checking it every so often while driving.. Dont want to hit high RPMS much.
How do i permanently repair?
Any advice would be helpful.
Also looking to buy the "water outlet cover" for a b16a2, or whatever it is called.. Is this the correct term?
Thank you in advance.
Old Feb 3, 2012 | 01:39 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: b16a2 94 Hatch Broken Coolant Bleeder Valve
19315-P30-J01 006 001 COVER, WATER OUTLET
19516-PC1-000 010 001 BOLT, BREATHING WATER
Old Feb 3, 2012 | 12:12 PM
Hey thanks a bunch. I really do appreciate it. I will try to share what knowledge I have as well.. Let me know if you need anything
White_EG1
Sep 18, 2016 11:41 AM
minituner
Jul 6, 2015 06:20 PM
den berre
Jul 30, 2013 01:15 AM
steveeb
Jun 7, 2013 07:14 AM
hundreds08
Mar 10, 2013 09:42 PM
