91 Auto stalling
Thanks for looking first and foremost...
I have a 91 Accord LX had some idle issues...
Posted a couple questions got some great advice and faloowed it. Now I come to any one who can help again. Just today while driving the car when I pressed the accelerator the cars RPM's dropped and the car stalled out. We just replaced the igniter is there anything I'm over looking?
the car Idles and starts great so thats why im confused....
Thanks Again for looking
No recent work other then replacing the igniter, prior to that I replaced the plugs and the cap and rotor seemed fine at that time. I was told it might be the intake is leaking do to it being loose is this a possablity? The car seems to be acting up more then usual recently
I just want my little Honda to run and run good. Not ready to give up on it yet.
i kinda have have the same problem but mine is honda civic 94 dx but it starts and runs but after awhile of driving it it well shut off and the check engine light goes on can i get some help please because i did a tune up and the car is still turning off and the dash lights turn on. including the check engine. could it be the fuel pump?
Its possible that its your ignition switch starting to go.its at about the right age that its you need to change the wire switch assembly.while in idle play with your key.jingle it a bit back n forth but dont turn it if it cuts out that might be your problem. If it only just started doing that this trick might not work
TedNes
Aug 10, 2004 08:55 PM
