just got blox lug nuts and now i find out i need washers.....
Old Feb 2, 2012 | 03:48 PM
billyinse's Avatar
Default just got blox lug nuts and now i find out i need washers.....
i have oem wheels and ordered blox lug nuts for my 99 integra. i just read that i will need washers & i found a place online that sells them for 75 cents each and im assuming they will work since its the 60degree to the ball socket.( i assume they are all the same?) just making sure this will work. also i do not have extended studs is this still ok?
thanks!
http://www.pacificcustoms.com/mm5/me...w=&range_high=
Old Feb 2, 2012 | 04:14 PM
TunerN00b's Avatar
Default Re: just got blox lug nuts and now i find out i need washers.....
thanks!
The best advice would be to use nuts appropriate for your wheels, but since you intend to ignore such advice, those should be fine if the description is accurate.
Extended studs are only needed if you can't get at least 7 threads engaged.
Old Feb 3, 2012 | 03:26 PM
billyinse's Avatar
i never got such advice. i just orderd lug nuts.... then found out they were not going to work and did a search and found out they made washer adapters. anyway thanks for the info. i just ordered new wheels so i can use the lug nuts without issue.
Old Feb 3, 2012 | 05:22 PM
bpoweredeg6's Avatar
what kind of wheels bc i had blox lugs on my oem si wheels and they worked fine
Old Feb 5, 2012 | 07:33 PM
toyomatt84's Avatar
Sanji
Umm... all factory Honda wheels pretty much share the ball-seats. You can use conical seat lug nuts, but they are very unsafe, as they do not seat properly to the wheel.
Old Feb 6, 2012 | 08:10 AM
tommycrx's Avatar
Yeah, I just don't see how a better looking lugnut is worth the potential of it flying off.
If you need something different, you can get ball seat nuts in black that were on the S2K CR.
PatrickGSR94
Feb 20, 2011 09:32 PM
Alpinestar03
Feb 6, 2009 08:55 PM
BMRALR
Feb 20, 2008 07:16 PM
wrx'n you
Dec 21, 2005 09:44 PM
bryant
Jun 17, 2003 04:24 PM
