Head gasket leak solution?
Old Feb 2, 2012 | 11:23 AM
MTracing's Avatar
Default Head gasket leak solution?
hey guys so i bought my civic about a year ago. And now i have a head gasket leak it has 110k miles and its a d16y8. I was wondering if there was any solution that you can buy from the store to fix the leak??? for example like the bars leaks head gasket repair solution??
Thanks guys for any help!
Old Feb 2, 2012 | 12:18 PM
mygoldeneg's Avatar
Default Re: Head gasket leak solution?
sure is its called buying a new headgasket gtfo
Old Feb 2, 2012 | 12:21 PM
Dc4LsTeG's Avatar
EK9
Originally Posted by mygoldeneg
sure buy a new headgasket
Old Feb 2, 2012 | 12:30 PM
MTracing's Avatar
yes i can buy a new head gasket, but installation is a pain!
Old Feb 2, 2012 | 12:31 PM
Dc4LsTeG's Avatar
EK9
Well that's the only way its gonna get fixed. There's no "band aid" for a head gasket
Old Feb 2, 2012 | 12:35 PM
MTracing's Avatar
ok, well if that is the only way it can be done. Then i guess that is what i will do. Thanks for the help. I was just curious because i went into orielly auto parts the other day and saw this bars head gasket leak sealant. So i was just wondering if anyone had used it and if it worked. But if you guys say that the only way is to replace it, then ill do it! thanks again
Dc4LsTeG's Avatar
EK9
Old Feb 2, 2012 | 12:38 PM
Builda'Teg_92's Avatar
That stuff is only sold beacuse people actually buy it.
Old Feb 2, 2012 | 05:02 PM
dntnedvtec's Avatar
....do the headgasket weaksauce....
Old Feb 2, 2012 | 09:28 PM
MTracing's Avatar
and what is that?
Old Feb 3, 2012 | 02:05 PM
dntnedvtec's Avatar
Nothing.
Old Feb 3, 2012 | 08:18 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Replacing the head gasket is the only lasting solution. However we occasionally get customers whos cars are worth less than the cost of repair. In such cases we suggest(but do not install) this:
http://www.usasealants.com/products/...asket-sealant/
Seems to work well. But the problem with this and other sealant is that there is no way to contain it to one part of the cooling system. It will eventually wreck havoc through out your cooling system and engine.
Old Feb 6, 2012 | 11:58 PM
ej8munster's Avatar
imagine....leaks in..copper flakes in the cylinders while running.....instant catalyst for destruction.... hot metal flying around in the cylinder equals detonation or pre- ignition and holes in piston or cylinder....
Cho0se
Feb 24, 2020 02:59 PM
Natural Aspirations
18
Dec 19, 2007 02:21 PM
john457
Jun 5, 2007 05:57 PM
john457
Mar 17, 2007 02:11 PM
da_33
Jan 11, 2007 11:12 AM
