EM1 B16a2 CHECK ENGINE LIGHT NEED HELP
Old Feb 2, 2012 | 07:16 AM
mrem1dipppn's Avatar
Default EM1 B16a2 CHECK ENGINE LIGHT NEED HELP
engine light comes on only sometimes and when it does it normally still runs generally fine but this morniing when i tried to vtec in 1st, \it only vteced till 6k rpms then my engine completely stopped accelerateing? untill i shifted to second. havent vteced since and thought id try and save alittle money then to take to a shop, have done research not some lazy *** but i think its my throttle position sensor? any help woud appreciated. also im 100% bone stock besides it being a diff b16 then orig one in my em1. please give advice!
Old Feb 2, 2012 | 07:19 AM
Former User's Avatar
Default Re: EM1 B16a2 CHECK ENGINE LIGHT NEED HELP
Read the CEL sticky at the top.
Old Feb 2, 2012 | 08:35 AM
my check engine light just says idle air malfunction.
Old Feb 2, 2012 | 08:37 AM
grumblemarc's Avatar
The Grumpiest
It said that? What code is it throwing specifically?
Old Feb 2, 2012 | 08:39 AM
Code 14? If you reset the ECU, does the same code return? If so, take your car to AutoZone to get the OBD2 code pulled with a code reader. The OBD2 code will be more informative.
Any idle problems?
Old Feb 2, 2012 | 08:58 AM
i checked the code about a week ago, my brother has the obd2 code reader and im not 100% what code it was but i do know it said idle air malfunction. will check again in a couple hours have some stuff to do. but there is a hose comin off the back of my intake manifold and its missin the actuall hose that plugs into it.. ive tried researching what vacum hose it is but no luck. i have to put a inch or two long hose with the other end closed or it will be constintly suckin in alot of air, and when i gas my car it will rev to right below 2k rpm and wont rev any higher unless i push pretty hard then will shoot up rpms.. but if i put the 1inch hose with the other end closed it runs really good 95% of the time with no idle issues at all.
Old Feb 2, 2012 | 09:02 AM
thinkin that hose is for my cruise control which i dont have? and also if that 1inch closed hose somewhat fixed the prob with the idle maybe a diff code is now coming up? will check code in a couple hours nd update. thanks for the feedback appreciated.
mien_civic715
Aug 19, 2010 09:19 PM
vstone
Jun 1, 2010 09:29 PM
civic-4-ges
Jan 24, 2004 08:28 AM
