HELP!!!! LOST MASTER KEY TO 5TH GEN. TYPE SH
Old Feb 1, 2012 | 12:21 PM
toukao35's Avatar
Icon3 HELP!!!! LOST MASTER KEY TO 5TH GEN. TYPE SH
I recently lost my main/master key for my prelude. Also, I had no spare key. I called honda and they said for me to tow my car there($65), then they would need to make me a key with a chip in it ($357) and reprogram it to my car ($120) ans thats not including tax. Thats labout $600! Just for one key. Dayem. Anyways i was woundering if there was any other way to get around this? Could I go pull out parts from another same generation prelude type sh and use there parts for my car? I was thinking I find a person thats parting out a prelude(same gen and sh model) that still has there key and wat parts would i need? Is this possiable? Thanks in Advance.
Old Feb 1, 2012 | 01:28 PM
afrotec's Avatar
Default Re: HELP!!!! LOST MASTER KEY TO 5TH GEN. TYPE SH
This exact same thing happened to me. I actually had my red key,but it didn't matter. Here's what you need to do to solve this:
1. Call up your Honda dealer, have them cut you a key based on your VIN. You'll probably have to go in to do this, but it can be done.
2. Find a good locksmith. I was lucky I had a pro in my area. He'll use the key made from the dealer as a template to make you a new key that will contain a chip. Then he should program the key to match the car. I believe he would need to hook up some kind of device to the car in order to read/write these codes.
This cost me less than $300. Honda was telling me I needed a new immobilizer unit and all kinds of crap. They said they'd do it for over $800... **** that.
If it helps at all, the locksmith I went to was Jose Hernandez, owner of Omega Locksmith. http://www.facebook.com/OmegaLocksmith
I hope you're able to get this worked out. Good luck!
Old Feb 1, 2012 | 01:48 PM
InvaderTrax's Avatar
Bypass immobilizer and get a regular key cut to your VIN
Old Feb 1, 2012 | 02:23 PM
toukao35's Avatar
thanks afrotec, u just saved me a couple hundred dollars.
how do i bypass the immobilizer?
Old Feb 1, 2012 | 03:44 PM
This should work http://www.j32a.com/showthread.php?t=270
Old Feb 2, 2012 | 07:43 AM
asianpoet's Avatar
or you could do this option.
http://www.ebay.com/itm/180736187568...84.m1438.l2649
then have the dealer/locksmith reprogram it
Old Feb 2, 2012 | 08:52 AM
toukao35's Avatar
thanks for all the info guys. It helped me alot and saved me a couple hundred dollars.
Old Feb 15, 2012 | 11:25 AM
Jibberjabber's Avatar
Yeah, locksmith is definitely the way to go in this situation. There are even guys who do it on ebay by mail. Send the immobilizer computer box and they send it back with keys programmed to it.
If you have a donor car you can switch parts but the key, immobilizer computer, and engine computer all have to be matched, so you would have to swap in the ignition lock and both computers from the donor car.
Old Feb 26, 2012 | 03:34 PM
curt207's Avatar
i had a similar situation. the cheapest way i found was to find a obd1 ecu since 97 ludes r obd2. then get a obd2a jumper harness to obd1 then as long as u have the obd2a wiring harness going to the motor this will bypass the immobilzer completly since obd1s dont read them or anything there fore alowing u to get a simple prelude key that will turn the ignition and bingo immobilzer bypassed. my total expenses for this was 150$ish. but i already had a spare key to turn ignition. also you cld try and go find a steering column with immobilzer and ignition in tact with a master key then redo the ecu through honda or some1 that knows how to do it as said b4. also the imobilzer box is easy to open up and if u know what ur doing with the circuit board find what u need to do to bypass it
Old Oct 22, 2012 | 01:38 AM
joe2012's Avatar
Icon4 Re: HELP!!!! LOST MASTER KEY TO 5TH GEN. TYPE SH
hi! well, i'm pretty sure that you can find some cheaper solutions in this other forum http://www.carkeyadvice.com/forum/fo...ey-Discussions they have already discuss the topic there! i lost my car keys too and in that same site i gave you, i found a list of car key specialist to call! i hope one of them can help you too! they are way much cheaper than the dealer.. just give it a try! ring them and get some quotes! cheers!
Junkticon
Nov 24, 2014 11:41 AM
scrabulot
Jan 23, 2008 01:16 PM
azludemonstah22
Jun 28, 2006 07:45 AM
92preludeSIwp
Jun 29, 2004 10:19 AM
D-Day
Jun 23, 2001 03:57 PM
