running rich d15b
when i give it full throttle the car kinda smokes. it smells like it could be gas. Im thinking the 02 sensor since the one it has is beat the f up. i have like 2 extra from a 00 tl type s. would it work it i re wire it? idk ima pull out the plug and see how they are tomorrow morning to see how its running. then if they check out fine a compression test. anymore tips? car runs GREAT and vtec hits as it should so im confused. Doesnt seem like a any cylinder has low compression. Oh and did a head gasket job just for the f of it and smoked before to though it might fit it. ooh well
Still smoking ima check the fpr next to make sure its not messed up. Anything else that can cause this?? it only smokes in idle and only after the cars been sitting for like 5 mins it slowly smokes a bit. Oh and when i give it a lil gas the idle revs up and down on its own from 1700rpm to 1800rpm. So when in gear it jerks back and forth in those rmps. the car is stick. I dont know what it could be.. maybe the fast idle sensor? Please if you got info i would really appreciated it.
Codes i got from the ecu AFTER i installed a light bulb for the check engine light.
Code 3
code 10
code 14
I know ones for the map the other for the iac and the last for the iat. Ive changed the iac and map. I checked the map i used and it was burned at the tip of it. SO im sure that think dont work no more. car idles fine but from 1500 to 1700 when in gear or neutral it revs up and down. Im seachering for info on testing the iac and map, im sure the map dont work but what are the colors for the wires that go to the map? and the ones that go to the iac? maybe i have them switched around
Code 3
code 10
code 14
okay so i fixed the map sensor... i didnt connect it.
THe iac and iat where switched
Now i only have one code.. code 10. Ima go buy a new sensor and get back and see f its down with.
Would a code 10 cause it to waste a lot of gas??
v8killaz
Mar 19, 2008 06:54 PM
ef_you_again
12
Mar 26, 2005 07:28 PM
