crx HF brake upgrade question
Old Jan 31, 2012 | 08:49 PM
tyvtec23's Avatar
Default crx HF brake upgrade question
hey HT i have a 91 HF and i recently bought a pair of 91 si rear disc breaks and i was wondering what master cylinder and proportioning valve could be used for the upgrade, i heard a civic ex from a EF sedan works, is this a direct bolt on process if so?
Old Feb 1, 2012 | 12:01 AM
tyvtec23's Avatar
Default Re: crx HF brake upgrade question
anyone?
Old Feb 1, 2012 | 11:00 AM
tyvtec23's Avatar
Old Feb 1, 2012 | 12:12 PM
.Manny.'s Avatar
Touching My Member
yes
Old Feb 1, 2012 | 12:32 PM
LSx Envy's Avatar
and use the integra 15/16" master cylinder if youre gonna upgrade that too..
Old Feb 2, 2012 | 07:41 PM
RexyHF's Avatar
If it was my car, I would consider upgrading to 9.5" rotors and calipers in the front too... or perhaps even the 10.3" ex front rotors and calipers to help balance out the brakes a bit.
Old Feb 3, 2012 | 10:56 AM
Nooch's Avatar
I was thinking about doing this too myself. What all would I need? Caliper, rotor... Caliper bracket? I can assume the same brake lines can be used?
Old Feb 3, 2012 | 01:18 PM
RexyHF's Avatar
If you are going to the 9.5" rotors in the front, you will need: the caliper, caliper bracket, rotor, and pads. Master cylinder and prop valve are optional. I didn't upgrade the master cylinder or prop valve and the brakes work pretty well. With the larger 10.3" rotors, I would probably upgrade: master cylinder, prop valve, plus all of the other components already mentioned.
ki11r0y1086
Suspension & Brakes
Nov 22, 2016 08:26 AM
hfcrx88
Suspension & Brakes
Apr 16, 2010 01:50 PM
PS122
Sep 20, 2009 08:17 AM
neozero999
14
Apr 14, 2008 03:03 AM
