klunking noise in front of car, help please
Old Jan 31, 2012 | 06:21 PM
sedorbrian's Avatar
Default klunking noise in front of car, help please
Ok heres what happens:
When driving, i let off the gas and hear a loud klunking noise, which gets loud if i turn to the left, and quiet if i turn to the right. But as i said, this is only while my foot is not on the gas, doesnt matter if its in gear or not. My thoughts were wheel bearing.
Old Jan 31, 2012 | 06:56 PM
hondaon18's's Avatar
Default Re: klunking noise in front of car, help please
Usually a wheel bearing hums and gets louder as u accelerate klunking would be more like ur half shaft
Old Jan 31, 2012 | 07:09 PM
BigRick903's Avatar
Bump I have the same problem I wuz told to replace trans mount it looks kinda bad but mine like knocks i guess that's a klucking right?
Old Jan 31, 2012 | 10:57 PM
civicjunkie17's Avatar
I'm guessing it's manual? It doesn't make the noise while stationary? Does it make the noise while moving in neutral?
Old Jan 31, 2012 | 11:51 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Check your engine mounts and axles. There's a ton of stuff that could be causing that klunk noise, but I'd start at the mounts and axles. Also check the bushings in your control arms.
Old Feb 1, 2012 | 12:45 AM
sedorbrian's Avatar
I just had new cv shafts put on not long ago. Does not make noise while while stationary, sound gets faster as car gets faster
Old Feb 1, 2012 | 01:53 AM
jbpnoman's Avatar
Check your bearings, as well as your mounts. Mounts are an easy visual check. For bearings, jack up the front end and try to wiggle the wheel up and down, as well as left and right. If it has noticeable movement up and down, check your ball joints. If it has noticeable movement left and right, check your bearings and tie rods.
prelude2.2
Jan 29, 2013 07:44 PM
ekferio
May 15, 2007 07:03 PM
caliprelude3087
Aug 26, 2004 10:02 PM
MeanGreenEG9
Dec 16, 2002 07:20 AM
