fuel loss ?
recently replaced the clogged fuel pump strainer . and now its not running properly .
i have a nasty sputter from 5500-8000. also when i come to a stop my car dies out .
ive looked over everything i can think of . fuel filters are replaced . fuel pump is pumping ,
could it be my fuel pressure regulator ?
its on my 88 ef hatch with a obd0 b18a1.
Sounds like a clogged fuel filter to me. Like said above you might have stirred up a lot of stuff in the tank when you changed the strainer. I would also check the injector screens and the injectors themselves. 40 psi with vacuum applied seems a little high to me, should be more around 35. This might be a sign of clogged fuel injectors.
all filters and screens are cleaned .
also a new fuel problem , im driving normal , and hit the brakes and my car dies. i have a full tank of fuel . and all vaccum lines are clean and clear .
all were replaced three days ago , not cleaned sorry for the mix up.
also found the problem .. went to change my timing belt , timing belt is still good .
the problem was a broken rocker arm.
Element3488
12
Nov 19, 2012 08:53 AM
cyrix12
32
Oct 24, 2006 07:42 AM
midwesta
10
Aug 3, 2005 03:06 AM
